Where to find new upper control arm bolt ?
Does anyone know where to find new pivot bolts for the upper front control arm ?
These are the bolts which the inboard end of the upper control arm bushing pivots on. (You can see the head and nut of them inside the engine bay sticking out of the chassis bosses down on the inner fender wells.)
I though they were just 16mm x 1.5 with a long shank. I bought news ones like that, then discovered the originals have a shank diameter of 17 mm, not 16 mm. Since this forms the pivot joint where it slips through the bushing, the news bolts have too much play with a bushing over them.
Is there some metric bolt spec I'm over looking ? I realize I may be able to get used ones at APE.
Cheers,
Jeff
JJB
1969 1750 Spider Veloce
