Old 08-21-2004, 07:56 PM
Dr. Don Dr. Don is offline
Advice wanted on replacement top and roll bar for 86 spider
I bought an 86 Spider last weekend. Before letting anyone drive it, I want to install a roll bar and fix the rear window that is coming out. The stitching on the rear window has come out. the previous owner suggested taking it to a shop and having it restitched. Although that is a possibility, I have to remove the top and then reinstall. It seems to me that I may be just as well off to buy a new top. What is the thinking on this problem?
Secondly, my daughter and wife will be driving the car, and my wife wants me to install a roll bar before either of them drive the car. Mike Besic has suggested a "street" bar. What experience do you have with the bars available for IAP,etc regarding interference with seat travel, top fitting, installation etc.? I do almost all my own work on my cars, so I expect to install the bar myself.
Dr. Don
69 GTV
90 300ZX
86 Spider
96 Villager
Old 08-22-2004, 12:28 AM
dwc dwc is offline
Hi Dr. Don:
One significant problem with the installation of a rollbar in an L-Jet Spider is that mounting isn't quite the bolt-in situation that the rollbar vendors would have you believe. The parcel shelf (for lack of a better term) will have to be removed or cut, and the FI ECU will have to be slightly relocated. There is also an interference issue with the shoulder belts.
Having said that, it's my feeling that the very real problem with a rollbar in a street-driven Spider is the risk of serious head injury, if one were rear-ended, for example. That's certainly a much more likely occurence than landing a Spider wrong side up. Take a look at the pic I've attached, of an Autopower street bar installed in a '74 Spider, and note the proximity of the rollbar to the seat backs and headrests. Dimensionally, the '74 cockpit is identical to your '86. Another issue is the strength of the rollbar in question, and whether or not it would actually support the weight of the car, including the added energy likely to accompany a situation that would up-end the car. While the rear deck of an '86 Spider is a bit more substantial than that of a '74, it's still structurally weak, and the Autopower-supplied rollbar mounting plates and hardware would certainly never pass tech inspection at any SCCA, SVRA, or similar, track event.
So, there you have one Alfa Spider owner's (25+ years) opinion. I've got quite a bit of ER work and educational experience, too, and the head injuries I've seen prompted the removal of the rollbar from my '74 Spider.
Regards,
Dean
Lutz, FL
'74 & '87 Spider Veloce's
Old 08-22-2004, 01:02 PM
bill_bain bill_bain is offline
Roll bars redux
To Dean's point, the area underneath the parcel shelf is an open box section and SCCA and AROC have been concerned for some time that the top of the open box section would deform from the lateral loads put on it in a roll over situation since the initial load is lateral as the car rolls over. The obvious solution is brace the box section by welding in reinforcements. The most common way is probably to use "black iron" pipe as reinforcing tubes between the backing plate on the bottom of the "chassis" and run the bolts though the pipes. Since the pipes are in compression between the plates on the roll bar and the backing plates, the top of the box section has a much smaller likelihood of deforming as the lateral loads differentially act on the sides of the roll bar. There are probaby a dozen other ways to achieve the same reinforcement goal, but an unreinforced rollbar is defintely NOT a good idea.
Most street bars are designed to let the top close over them. This means that for many drivers they will NOT be high enough to keep the passengers' heads off the pavement when the car is in "inverted flight." A street roll bar does not have a diagonal cross brace. SCCA and AROC consider one a neccessity to reduce the potential for the bar to deform and collapse. In a side impact with roll over, if one side of a street bar were to become "tucked in" from the initial impact, it could collapse, with disasterous effect. Many "street" bars are made from thinner materal of a smaller diameter than the sanctioning bodies would allow (The AROC Competiton Code gives material types and dimensions). The lack of height, plus the lack of a diagonal brace, and the sometimes questionable choice of materials, would give me pause concerning their utility as a safety device -- better than nothing, I guess, but it's not clear how much better.
The "race" roll bars with diagonal braces will not permit the top to be closed, which rules them out for most street Spiders, although IIRC that Russ Neely of AROC figured out a way to replace some of the bolts in his top frame with clevis pins so he could unpin the frame, hoist the top over the bar and then pin it back together. It worked with the Autopower race bar, I'm told.
Lastly, a rollbar should ALWAYS be padded appropriately. The Snell SA standards incude an impact test for the helmet hitting the roll bar so it's not merely an abstract possibility. Autopower makes fancy vinyl covered padding for the street bar, but the other alternative is to use the foam paddiing that is ubiquitously seen in race cars. Whether the padding would affect the ability to close the top, I don't know, but the risk of whacking your noggin on an unpadded hunk of steel is significant and probably greater than the chances of a roll over.
As far as installation goes, most Bosch Spider owners who have put a roll bar in report that although it's tight on the passenger side, they do not have to relocate the ECU. I did not with the Autopower race bar I have in my '83, but the street bar may be narrower than the race bar, which would put the foot of the bar in the tangle of wires, fuses and relays just outside the ECU brackets.
If you're still wanting a street bar, the best thing to do is to find a race car fabricator (Mike, I'm sure, knows of one) and have the bar custom made of appropriate materials and mounted properly. Unless you're VERY good at metal fabrication, and welding, a proper mounting job is not something for an amateur -- the box section is NOT square, but IS trapazoidal in both the forward and lateral dimensions, whcih makes getting the reinforement tubes into the right spot, lined up and properly welded a non-trivial task. Also, the main power cable from the battery to the starter is in the way and can be easily nicked as one is drilling.
Hope that helps!
Bill Bain
AROC Atlanta
'83 Spider Veloce
'03 Mazda Protege5 (Red - zoom, zoom!)
ex - '87 Milano Silver (RIP)
