My Duetto has recently developed a good amount of clutch shudder when I slowly release it with the gear lever in reverse. I'm not experiencing similar problems when moving in any of the forward gears, so I'm guessing that the clutch is not the culprit.
I did a quick search on Alfa Digest (nothing found in this forum), and came across some old posts describing what appears to be a similar phenomenon, and attributing the problem to the transmission mount. Since I had only recently replaced that part, until I started reading those posts, I had presumed that that was not the cause.
Has anyone ever experienced a similar problem? Could the problem be with the transmission mount?
Here are the links to the Digest posts re: the problem:
Digest Link #1 Digest Link #2 Digest Link #3
