[quote=ghnl;504560]I'm pretty sure your '87 would have a limited slip differential.
BTW, make sure you can remove the fill plug
before you drain the differential...
Good point, GNHL. I had trouble removing the filler plug on my Series 3 car. Couldn't move it with allen key wrench. I succeeded eventually by using a short length of 13mm hex bar connected by a socket to my 12V electric wheel wrench. Fantastic result.
I was only removing it to check the level - I couldn't get any more oil in anyway!
