Old 08-06-2004, 03:04 PM
greg's Avatar
greg greg is offline
1969 Roundtail Numero Uno
Oil pressure
What should be the oil pressure on different RPMS at hot engine motronic after an hour driving.
1969 1750 boat serial 105.62.14800001 Numero UNO
ex 1992 spider can't afford 2
ex 1986 alfa33s
Old 08-06-2004, 03:21 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
Min 7 psi at idle
Min 50 psi at running rpm.
John Stewart
74 Spider
Old 08-06-2004, 03:23 PM
John M's Avatar
John M John M is offline
Alfa Poor in KY
And Greg:
Don't assume that the gauge is accurate. Get it checked independent of the Alfa gauges and sending unit.
Best Regards,
John M
1978 AR Spider Veloce 2000....the first and still here
1978 AR Spider Veloce 2000...soon to arrive, its black and its slow!
Old 08-06-2004, 03:29 PM
greg's Avatar
I replaced sending unit still same idle at 7-10 psi high RPM around 37-40 may its gauge it self ???????
ex 1986 alfa33s
Old 08-06-2004, 03:31 PM
greg's Avatar
also it kinda stuck at cold always at 54-56 psi
ex 1986 alfa33s
Old 08-06-2004, 04:20 PM
Roadtrip's Avatar
74 Alfa Spider
Greg - I wouldn't worry too much about 40 psi. The engine's probably wearing or the oil pump getting weaker, but 40 psi is still good. You might try a 20w50 oil if not doing so already.
John Stewart
74 Spider
