Doesn't sound like you're getting full disengagement of the driven disk. This could occur because of drag due to some broken pieces jammed in the assembly, but as you just had it disassembled, that's not likely.
I am posting two pages of the shop manual for the clutch & throwout bearing to help you visualize the assembly. I suppose it's too late to suggest that whenever you have things apart as you did a new throwout bearing and driven disk is cheap insurance, as is a careful inspection of the pressure plate assembly.
Note the "S" dimension shown in the center of page 77 (second post). Can you remember if the graphite ring was smooth, square, and still projecting from the face? If not, that could be creating the wobble you describe.
If you are satisfied that you've taken up all adjustment possible, you may need to pull it back apart and replace the bearing, disk, and perhaps the pressure plate.
Good Luck
Wil Painter
66 Giulia Sprint GT
94 164 LS (for sale)
