#16 (permalink)
Old 02-27-2008, 08:29 AM
Watch out which "experts" you invite.......These experts are the ones that may have caused this confusion with their claims in the first place......
  #17 (permalink)
Old 02-27-2008, 08:35 AM
Originally Posted by Elio Comello View Post
I believe the GL1/GL4 designation is for the NON Moly synchro's in the earlier gearboxes.
Alfa Factory spec PA381500000000 for the 115 Spider, which updates the English language workshop manual lists acceptable GL5 lubricants in Dino 80W/90 and Syn 75W/90.
An individual can learn a lot by going to the Red Line website.
The "correct" Red Line oil for our transmission is 75W90NS.
One should bear in mind that we are looking at 20+ year old transmissions, Syn gear oils started to come on the scene not much before that time. Oil formulations even for the same product are much different today (2008).
All oils when reformulated, still need to be re-certified to carry their respective SAE and API Classifications.
Elio
OK, Elio, you are Hillary, and I am Barak, and "you were my friend before this thread, and you will still be my friend after this thread"....LOLOLOL
I have been on that redline site, and it is kinda scant as far as specifications/additives go. They cant be the only ones making a gear oil for our alfas. Industry/business doesnt work that way. They are dispelling "dark science" to the point of having duped the alfa comunity into thinking they are the only ones that will save our synchros. They are lacking , to me, of objective info, and specs.
Naturally suspicious,
Joe (Giuseppe)
  #18 (permalink)
Old 02-27-2008, 08:40 AM
Alfacliff Alfacliff is offline
I dont know additives or work for any suppliers of oil, I only know I put in redline mtl in the winter of 2005 and my transmission shifts much better in my 74 spider.
cliff
  #19 (permalink)
Old 02-27-2008, 08:43 AM
lowmileage's Avatar
ReAlfisted 3/06
cliff
and no leaks?
1973 GTV - bought 3/06
1969 GTV, #AR1530021 - sold 10/72
  #20 (permalink)
Old 02-27-2008, 08:49 AM
oldschooleuros's Avatar
oldschooleuros oldschooleuros is offline
Redline is a good trans oil, as well as for diffs.
BG synroshift 1 and 2 both can substitute ATF and require no additives. There are road race and drag cars using it. I have personaly experience it, and it feels like a trans rebuild lol. No problems ever.
[COLOR="Green"]When cornering hard.... It's not the tires screaming...[/COLOR] [COLOR="Red"]It's the road begging for mercy. [/COLOR]
[COLOR="Red"]1985 Maserati[/COLOR][COLOR="Green"] Biturbo, 5spd. A work in progress. [/COLOR]
  #21 (permalink)
Old 02-27-2008, 09:38 AM
Elio Comello Elio Comello is online now
Giuseppe, let me assure you you have not and are not about to lose 50% of your italian friends. BTW does your middle name start with an "H"?
Oil chemistry is NOT like analytical and pure chemistry, it is like wine making, certain aspects are dark science.
I would only advise that you put in GL5 spec oil in your trans "project". Whether it is Dino or Syn is your choice, but I would advise NOT to go with GL1/GL4.
(BTW I worked as an instrument engineer in process control in the lube plant, research pilot plant and test plant of one of the major lube oil refiners)
Ciao Giuseppe, snowing up here!, send some Spring please!
Elio
  #22 (permalink)
Old 02-27-2008, 09:59 AM
Elio
Whew (wiping sweat from forehead), glad I still have you guys as friends..LOL.
Hey Elio, thanks for shedding light on the dark aspect of this subject. OK, You convinced me not to use GL4. I will probably order some spirax 80w-90.
(darn, does this mean this thread may die now?)
Just realized I dont have to cover my coffee tree...it froze last month with that 40 degre cold snap..........maybe it will sprout in May??
  #23 (permalink)
Old 02-27-2008, 10:39 AM
WopJob's Avatar
WopJob WopJob is offline
My 2 cents: I just put Redline MTL90 (75W-90) in my spider trans to help with extreme cold weather drivability. It helped. I can change gears in 35F degree weather without waiting for 45 minutes before driving off. I had Spirax 80W-90 before. Both are recommended for spider trans. There was nothing wrong with the Spirax in the summer.
I know that this does not answer your question about the GL4 vs GL5 dilemma, and definetly does not put the issue to rest. I'm not sure that we can find the differences between the two (who wants to try and post the unobjective results?). there will always be some question of objectivity in the research. That's why the issue of OIL, coolant, and brake fluid will not go away.
ps. Nissan was mentioned before, what year and model are we talking about?
Tony G. in NJ
87 Graduate - Calimero '90 Toyota Tercel - Babbaluci
  #24 (permalink)
Old 02-27-2008, 11:09 AM
lowmileage's Avatar
ReAlfisted 3/06
Nissan 1991 Sentra SE-R's anyway. It calls specifically for a GL4 and most guys run MT90.
Redline 75W90 GL5+ Hypoid Gear Oil - SR20 Forum
  #25 (permalink)
Old 02-27-2008, 11:27 AM
Gubi's Avatar
Gubi Gubi is offline
Originally Posted by Joe Papa Sr View Post
How can you make sense of it all? If you say the spec is GL5, then turn around and say Spirax is GL5 but without additives, when GL5 is basically WITH these additives , made for the hypoid gears, which are not even in the gearbox!! That is contradictory.
Originally Posted by Zungie
The confusion stems from the preference to use Redline synthetic oils. For the differential Redline 75W/90 is great. It contains EP (Extreme Pressure) modifiers. The EP modifiers however, make the oil too slippery to use in the gearbox, as the synchros won't like this. Thus, for the transmission one must use synthetic Redline 75W/90 NS. The "NS" (Non-Slip) being the critical designation, meaning that it does not contain the EP modifiers that make the oil too slippery.
The problem is that you guys are confusing the additives. The GL-5 hypoid additives are EP additives (extreme pressure) and are not what mess up the synchronizers. The limited slip additive (a friction modifier, which is not in Spirax or Redline 75W90NS) is what messes up the synchronizers.
Spirax *absolutely* has EP additives, otherwise if you used it in the diff your pinion and ring gears would eat themselves.
There's an awful lot of debate about this subject considering that the factory recommended Spirax is cheap and works well
1991 Spider
1987 Milano Gold
  #26 (permalink)
Old 02-27-2008, 12:49 PM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
Gubi,
Yes, I did confuse the additives... I stand corrected on that description. However, I'm not confused as to the reason why the additive is not good for the tranny, and which product is supposed to go into the differential or gearbox, regardless of this being the factory specified Spirax or the synthetic Redline products...
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
  #27 (permalink)
Old 02-27-2008, 12:52 PM
Gubi hit the nail on the head, as usual....
And Giuseppe, the coffee tree will sprout again, only the top that got hit by the cold will die, look for a new sprout and cut off the dead top above the new sprout. What spec water are you going to give the poor thing?
Elio
  #28 (permalink)
Old 02-27-2008, 02:28 PM
papajam's Avatar
papajam papajam is online now
with the Librarian
Now I'm confused. A limited slip additive reduces friction and a syncro works on the principle of friction. Would this then not improve the shifting by increasing the syncro friction?
I'm now at a loss as to how to explain why, after draining a hypoid EP gear oil out of an Alfa gearbox that had shifting issues, and replacing it with a non-EP lubricant (50 weight engine oil to be exact) that the shifting issues disappear.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
  #29 (permalink)
Old 02-27-2008, 02:36 PM
jarrington's Avatar
jarrington jarrington is offline
From what I understand that's exactly it - the synchros need to have enough friction to work properly.
-Jason
Jason Arrington
'60 Giulietta Spider
'74 Spider - For Sale
'67 Super project
'98 M3 Sedan
'04 Mazda TurboCumminsSuperDieselMax MPV (Alfa tow rig)
  #30 (permalink)
Old 02-27-2008, 02:57 PM
Gubi's Avatar
