Chassis Stiffener - Page 3 - Alfa Romeo Bulletin Board & Forums
  #31 (permalink)
Old 01-31-2010, 03:59 AM
Rich's Avatar
Originally Posted by msiert View Post
Anyone have a problem lineing up the chassis stiffener front bracket holes to the steering box bolts???
Hey Murray,
Check this tread by Tifosi, http://www.alfabb.com/bb/forums/susp...my-spider.html
Rich
1974 Spider 2.0L
  #32 (permalink)
Old 02-07-2010, 07:02 AM
fgc fgc is offline
Hi just a thought ... I think the stiffener may not fit RHD spiders.
I've been eyeing a chassis stiffener for ages but I gave up buying a stock one from the USA bec I noticed from pictures that the long sections running from front to back runs right next to the chassis rails so much so that I think it will foul the brake MC since they occupy the same space.
I think the later LHD spider has wall mounted brake booster and MC unlike the RHD with under chassis MC.
I think you'll have to modify or redesign the existing one inorder to fit RHD spiders.
Will be most happy to be proven wrong on this and if so proven wrong ... I'll be the first to place an order for the stock stiffener
fgc
67 RHD 1750 spider
  #33 (permalink)
Old 02-07-2010, 07:38 AM
fgc,
This has been a concern of mine but I have put it on the back burner because of other Alfa matters. Its an interesting question.
Where are you?
Stuart
  #34 (permalink)
Old 02-07-2010, 01:32 PM
Exclamation
Hello fgc and alfazagato,
I have a 1971 Alfa Spider 1750 (RHD, built for the Australian market). It has floor mounted pedals, and I agree that the brake master cylinder blocks the path of the right hand side longitudinal rail.
In hope I've sent an e-mail to Don Ereminas to find out whether a Chassis Stiffener for Spiders like mine was ever developed, as well as whether altering the stiffener currently sold (by cutting, inserting additional square section tubing, and re-welding) will compromise the integrity of the device.
I understand that Don is a helpful and obliging fellow, hopefully I'll get a reply.
Cheers,
Andrew Matusiewicz
Canberra ACT Australia
  #35 (permalink)
Old 03-08-2010, 01:42 PM
Chassis Stiffener
Hi,
did anybody built his own chassis stiffener ever and would be able to share the plans with me? 86' Spider
  #36 (permalink)
Old 03-08-2010, 03:18 PM
Rich's Avatar
Hi Andrew,
What was the reply from Don, regarding RHD cars?
1974 Spider 2.0L
  #37 (permalink)
Old 03-12-2010, 07:17 PM
Hi Rich
I'm on holiday at the moment (Tasmania) and just checked my e-mail.
Err, unfortunately Don (or anyone else) didn't reply.
However, an alfa mechanic mate of mine has a fabricator mate who will look into what is required to modify a stiffener to fit around the brake master cylinder and still maintain the requisite stiffness.
Should have an answer in about 2 weeks time.
Cheers,
Andrew
  #38 (permalink)
Old 03-14-2010, 05:38 AM
Rich's Avatar
That would be great Andrew.
Thank you for responding while your on holidays.
1974 Spider 2.0L
  #39 (permalink)
Old 03-14-2010, 08:57 AM
maxwedge's Avatar
One of these days I'm planning to build my own stiffner. I have lots of tubing and a welder in the garage, but what I don't have is lot's of time right now.
  #40 (permalink)
Old 11-17-2011, 05:01 AM
fgc fgc is offline
RHD chassis stiffener?
Anyone any luck with chassis stiffener for RHD cars?
Cheers
  #41 (permalink)
Old 11-18-2011, 01:41 AM
Yes they definitely fit!
Hi Folks,
Yes the stiffener certainly fits a RHD spider with floor mounted pedals. You have to remove the shield covering the brake master cylinder, and loosen the brake master cylinder bolts (tightening them after you've fitted the stiffener). Clearance is tight but nothing master cylinder-wise needs to be altered.
Makes a great difference to the Spider.
I have responded on this issue on another thread on this BB; here's the link.
http://www.alfabb.com/bb/forums/spid...g-frame-2.html
Hope this helps!
Cheers,
Andrew Matusiewicz
1971 Alfa Spider 1750 Veloce
1983 Alfasud Ti QV
  #42 (permalink)
Old 07-03-2012, 01:33 AM
fgc fgc is offline
Originally Posted by 'Sud Mania View Post
Hi Folks,
Whoah Andrew, what faith! You actually paid for it to be shipped all the way to Australia without knowing for sure that it will fit! Real cool Fantastic!
I am quite a bit late to this party as my spider had been in the body shop for an inside-out upside down bare metal job. It will finally be out ready for refiting in the next few weeks. Cant wait to fit one of these on!
Will just have to carry a smaller passenger to make up for the 40lb additional weight.
Thanks for the update!
fgc
1967 1750 spider
2004 156 2.0 JTS
2005 156 2.0 JTS Sportswagon
  #43 (permalink)
Old 07-03-2012, 03:23 AM
Talking
Hi fgc,
It wasn't a complete guess - from memory the early Spiders (e.g. Duettos) had floor mounted pedals (whether LHD or RHD), and the chassis stiffener supposedly fitted them.
Nonetheless, I suppose I did take a bit of a gamble... ... but I felt it was a case of nothing ventured, nothing gained.
Hope your Spider is all you wish for when it's complete!
Cheers,
Andrew Matusiewicz
