Old 07-30-2004, 12:57 AM
JustABloke JustABloke is offline
Send a message via MSN to JustABloke
Prop Shaft greasing.
Hi guy's
How often should the prop shaft be greased? and what would be a suitable grease to use.
My car is a '86 spider, my mates car is a 1750 GTV I imagine the same regime could be applied to both?
TIA
JaB
'86 Spider Veloce,
'70 1750 Berlina LPG Powered!
Old 07-30-2004, 06:04 PM
Sprintman27's Avatar
Sprintman27 Sprintman27 is offline
How do you get the grease on!!
Every 15000 miles according to the handbook.
But how on earth do you do it? Its not clear from the diagrams.
the splines are covered by the front driveshaft... surely you dont have to separate them. I recall a digram of a cut out to allow grease ro be inserted but there isnt one on mine!!
Can sombody explain the correct procedure, a clear digital photo would help a lot . It creaks and sticks so its well overdue for attention
Many thanks
Old 07-30-2004, 08:16 PM
il_formaggio's Avatar
il_formaggio il_formaggio is offline
I believe there's a zerk fitting you can attach a grease gun to. You may have to rotate the driveshaft by hand to expose it. Half turn at most to find it. Be careful you don't run yourself over in the process.
Gary C
'86 Spider Veloce, '97 Volvo 850R
Old 07-30-2004, 08:26 PM
Is that like a grease nipple?
Anybody got a link to a picture
Old 07-30-2004, 09:37 PM
Yeah, same thing. You should be able to find a grease gun at any parts store.
Gary C
Old 07-30-2004, 09:38 PM
jamieandthemagi jamieandthemagi is offline
Yep there are 2 grease nipples, one next to each universal joint in the prop.
Just squirt in the grease untill it ouses out the sides - not too much though or the prop will fling all the excess grease all over the underside of the prop tunnel.
do mine every 6 months just too make sure (6000 miles)
Jamieandthemagictorch
[IMG]http://upload.alfa145.com/files/8/AlfaSpider/AlfaSpiderCollageC.jpg[/IMG]
Old 07-30-2004, 10:11 PM
Great.. will have a go tonight.
Anybody going to the Northern Alfa Day in Leeds (UK) on the 15th?
Old 07-30-2004, 11:37 PM
RicksAlfas's Avatar
RicksAlfas RicksAlfas is offline
Thumbs up
Yes! I am.
It's my local bash and was a good do last year.
1968 1750 GTV ~ 2004 147 Lusso ~ 2006 Brera SV
Old 07-31-2004, 04:03 AM
VeloceMitch VeloceMitch is offline
And me, Ricks going to Grease my nipples for me, and waxoil my bottom as well.
You did agree to that didn't you...
Mitch
1968 1750 GTV
2003 156 JTS
Old 08-02-2004, 05:03 PM
well and truly greased!!
Could only find the slip yoke one though
It has reduced the lurching through the drivetrain somewhat
Thanks for the advice
