Roundtail versus later hoods - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Dr.G
post #1 of 10 (permalink) Old 03-20-2017, 08:27 AM Thread Starter
Dr.G's Avatar
I searched, but didn't see an answer.
Does a 70's or later engine hood fit a 1967 through 1969 Spider?
Dr.G is offline
post #2 of 10 (permalink) Old 03-20-2017, 09:11 AM
not2old4toys's Avatar
They fit however the bracing is different and the strut is on the right side 67 only. 69 may be different.
Cheers, Jon
not2old4toys is online now
post #3 of 10 (permalink) Old 03-20-2017, 10:11 AM Thread Starter
Dr.G's Avatar
Thanks Jon. My 1969 has the hood strut on the left. I'll have to look at pictures of the bracing.
Dr.G is offline
post #4 of 10 (permalink) Old 03-20-2017, 12:12 PM
USTA BE AN AD-MIN
ossodiseppia's Avatar
Later model hoods will fit. Most folks won't know the difference between the hood bracing. There are subtle differences in the sheet metal stamping on the intake side. The hood prop will work with the later model.
ossodiseppia is offline
post #5 of 10 (permalink) Old 03-20-2017, 06:24 PM
The 66-67 Duetto with its 1600 cc engine is pretty tight in hood clearance. Remember some of us have clipped the oil pan on potholes and DENTED the hood from the inside!!
The later cars, with their 1750 and 2L engines (about 5 mm taller) squeeze this even closer. Hence the changes in the hood bracing. This gets the cross beams a bit away from the front of the cylinder head - where the clearance is really tight.
Robert
60sRacer is offline
post #6 of 10 (permalink) Old 03-21-2017, 08:30 AM Thread Starter
Dr.G's Avatar
Robert;
If you'd only used 155/15 skinny old tires for your oil pan!
I'm feeling old. My wife likes the 155/15 tires because the car is higher off the ground than the other car with 195/60-14 Toyos.
Dr.G is offline
post #7 of 10 (permalink) Old 03-21-2017, 10:45 AM
hood
Photos show the difference in hood frame braces. Note the indentation on the driver side in the 66-67 hood to clear the stock battery. I would be curious to know which hood was used on non-USA Roundtail 68-70.
Cheers, Jon
post #8 of 10 (permalink) Old 03-21-2017, 10:54 AM
USTA BE AN AD-MIN
OOOPs, disregard my previous post. The subtle differences are between the 69 on.
post #9 of 10 (permalink) Old 03-21-2017, 02:22 PM
Originally Posted by Dr.G View Post
Robert;
Actually, I was on OEM tires, back in 1972. But i was also in downtown Boston, and hit a "new" pothole after a snow alert that was REALLY deep! Cracked the oil pan, barely got back home with oil pouring out!!
I agree that there is a lot to like about the light, nimble handling of the original Duetto suspension. I've driven full-up race cars too, and love that, but that early nimbleness was quite a memory.
Robert
60sRacer is offline
post #10 of 10 (permalink) Old 03-21-2017, 03:19 PM Thread Starter
Dr.G's Avatar
differences
Jon, to answer your Euro question:
This is the hood that came from a Duetto sold in Germany. By the Duetto register numbers, the hood is from a car which is 20 or so bodies from the end of the Duetto line.
It's going to get a later style radiator, so it has the radiator mounting metal retrofitted.
ossodiseppia likes this.
Dr.G is offline
