Vin's S4 Transmission Rebuild for Dummies - Alfa Romeo Bulletin Board & Forums
 6Likes
post #1 of 99 (permalink) Old 03-18-2017, 07:02 PM Thread Starter
Vintre's Avatar
Hello All,
1991 Spider with about 100K miles.
Firstly, I want to thank all of those before me who have posted threads on our transmissions. I did a ton of reading and learned a lot from you. Thank you.
Special thanks to Papajam, who walked me through this over several calls. He always takes my calls and never makes me feel foolish for asking all those newbie questions. A true Mentor in every sense of the word.
Honorable mention goes to Alfar7, Gordon Raymond, ARwrench, racingswim2006, who all helped me on several other threads I posted during the build and mcola who visited during the build and caught a bad throw out bearing for me. If I missed anyone, thank you.
During my preparation for the rebuild, I could find quite a few threads on transmissions rebuilds but I couldnt find a complete thread on dissassembly AND assembly. As of tonight, I am at the point of re-sealing the cases, so no excuses from me.
I am writing this thread from my perspective, the ultimate "dummies series user". I'm no mechanic but can follow instructions pretty well. This means tons and tons of pictures.
The thread is meant for the novice like me, so the experienced people in the group may find it a bit much. Fair warning.
My motivation was the start of 2nd and 3rd gear grind.
My plans going in was:
Apply the 1st Gear fix found on the AlfaBB
All new syncro rings
All new syncro sleeves
Dog gear replacement on 1st, 2nd and 3rd
And of course whatever Alfa surprises await
Like I said, there are a lot of pictures, so be patient with me as I post.
So..........lets start!!!!!!!!!!!!!
AngloSpider and mcola like this.
Vintre is offline
post #2 of 99 (permalink) Old 03-18-2017, 07:38 PM Thread Starter
Vintre's Avatar
Uh oh! This may take awhile. I need to resize my pictures!
Couple of "tools" that are indispensable, are a camera, baggies and marker. I used these a lot to keep my memory straight.
I am going to start assuming you already have pulled the transmission.
If you havent, here is a really good thread. The only difference I would say is that I did not remove all the bolsters. I removed the 2 side carpet pieces and the leather shifter boot.
Gearbox/Transmission Removal
I used 6" connected gear clamps to keep the compression on the donut
Remove the 3 19mm nuts securing the donut to the propeller
Now you can remove the propeller by pulling straight back
Remove this rubber part.
Vintre is offline
post #3 of 99 (permalink) Old 03-18-2017, 07:43 PM Thread Starter
Vintre's Avatar
The nut holding the propeller is staked in 2 places. Remove the stake. I used a nail.
Using a 1 1/4" socket remove the nut.
Now, pull straight back and remove the propeller
Remove 2, 10mm bolts holding the speedo
Vintre is offline
post #4 of 99 (permalink) Old 03-18-2017, 07:49 PM Thread Starter
Vintre's Avatar
Remove the speedo
From the top of the transmission, remove the top washer, the rubber piece, 2 sliding plates
Remove this next piece by pulling up
Remove this piece that wont't allow you to accidently put the car in reverse.
Vintre is offline
post #5 of 99 (permalink) Old 03-18-2017, 07:51 PM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
Did you replace the Propshaft Bushing?
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #6 of 99 (permalink) Old 03-18-2017, 11:17 PM Thread Starter
Vintre's Avatar
Remove 2 10mm bolts holding breather tubes
Remove breather tubes (you can't see them here, but there are washers)
Now you can remove the shifter (take careful note of the washers on each side, they are different)
Remove 13mm nuts holding the rear case
Vintre is offline
post #7 of 99 (permalink) Old 03-18-2017, 11:23 PM Thread Starter
Vintre's Avatar
With a few love taps, separate the rear housing
Here, 5th gear and reverse are revealed. 5th gear is the farthest gear to the right and reverse is the gear that has the straight cuts.
Now is a good time to evaluate the "olive". Here you can see mine is nice and round.
And a good time to inspect the prop shaft bushing the olive goes into. Nice and round as well, no distortions. A little dry, so I will need to remember to grease before installing.
Now we move to the inside of the bell housing. Disconnect the reverse light switch.
Vintre is offline
post #8 of 99 (permalink) Old 03-18-2017, 11:30 PM Thread Starter
Vintre's Avatar
Remove the throwout bearing
Inspect the bearing. Mine had some strange wear marks from the fork. The bearing was bad. Was not smooth when turned but felt like it was full of sand. Was on it's way out. I replaced it in 2011 and less than 10K miles ago. Last aftermarket bearing I use!
Remove shaft sleeve
Vintre is offline
post #9 of 99 (permalink) Old 03-18-2017, 11:36 PM Thread Starter
Vintre's Avatar
Remove 17mm nuts
Remove the reverse light switch using 22mm socket
A few love taps and separate the bellhousing
Vintre is offline
post #10 of 99 (permalink) Old 03-18-2017, 11:45 PM Thread Starter
Vintre's Avatar
Bellhousing is separated. Here we can see that the sealant used is a liquid type.
Moving to the centre case, remove the nuts/washers/bolts, taking careful note of where each go.
Vintre is offline
post #11 of 99 (permalink) Old 03-18-2017, 11:51 PM Thread Starter
Vintre's Avatar
More
Here are the 2 long bolts that go all the way through both cases
Vintre is offline
post #12 of 99 (permalink) Old 03-18-2017, 11:59 PM Thread Starter
Vintre's Avatar
Remove 2, 10mm bolts holding the shift fork springs assembly
Be carefull as these 3 "tophats" have springs under them and they might pop up
Remove the plate
Here is the spring
Vintre is offline
post #13 of 99 (permalink) Old 03-19-2017, 12:05 AM Thread Starter
Vintre's Avatar
Here is the ball at the bottom of each tophat
A little love tap here and the other tophats come up. Remove them and the springs.
Turn the transmission over and collect the little balls.
Vintre is offline
post #14 of 99 (permalink) Old 03-19-2017, 12:21 AM Thread Starter
Vintre's Avatar
A love tap or two and the cases separate
And here we are! Note, that for the rest of the thread I tried to keep the placement of the transmission as in car position. Left is towards the engine and right is towards trunk.
Thanks to jcslocum for this picture and labels. I used it a few times during the rebuild
My drain plug is magnetic. Changed the fluid a few years ago (maybe too long). Filings are fine, no large metal pieces.
Remove the layshaft
Vintre is offline
post #15 of 99 (permalink) Old 03-19-2017, 12:32 AM Thread Starter
Vintre's Avatar
Note here how the 4/3 and the 2/1 syncro hubs are aligned. Will need to install them the same way.
To remove the mainshaft, the 5th/Reverse fork has to be removed. Each fork is held to the shift rods by a bolt, bend tab and an alignment "washer",
Bend the tab back. These tabs are important to keep the bolt in. Should the bolt come out, you will not be able to shift into gear and possibly, most likely, cause a lot of damage to the gears. I was lucky in that I found the bolt on 2/1 loose, but the tab kept it in place!
Vintre is offline
