Replaced Plugs...now runs really rich???
Ok, I need a little help here. I replaced the plugs in my 82 spider with new Bosch Platinum 4's. I started the car, with no problem...but it wasn't running right.
It seems to be running rich as I could smell gas in the exhaust...or maybe I had a bad plug.
So I pulled the plugs...and they're all sparking fine...and all of them looked like they had fired in the cylinders. I put them back and checked the wires to make sure I had them in the right order. Yup...no problem.
I started the car with the same results. So, I replaced the plugs with the old ones...thinking I had the wrong plugs. Started the car...same results.
Now, the only thing I can think is that somehow the distributor is now not firing at the right times? or that the mass air flow sensor is not working properly.
Can anyone help? Thanks,
Woody
1982 Spider
