Old 05-13-2004, 09:44 PM
Farace's Avatar
Farace Farace is offline
Blocked water passages?
I got my engine block back from the machine shop today. Looking down into the block by where each cylinder liner goes, next to each head stud, is what looks like a water passage. By the second pair of studs are round holes, by the third are triangular holes, by the fourth are round holes again, and by the fifth pair of studs are triangular holes. Do these go anywhere, or are they blind passages? Most of mine seem to be blocked with this white chalky corrosion. I've been scratching and chipping away at it, but I don't know how far the holes go. Will I bottom out, or do these lead somewhere? I think I'm going to remove the head studs both to clean them off and to get better access inside the block.
Bob Farace
Old 05-14-2004, 05:41 AM
papajam's Avatar
papajam papajam is offline
with the Librarian
If I'm thinking correctly of what you're describing, they're blind holes.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 05-14-2004, 08:23 AM
Farace's Avatar
Okay, good, that simplifies things a little. I was worried there were passages leading off in another direction. These holes are the ones that head down in the general direction of the main bearings. Thanks!
Bob Farace
