  #91 (permalink)
Old 02-24-2008, 06:30 PM
Dietrich Dietrich is offline
Bondo is really handy for making molds, by the way.
Hot Springs, Arkansas
'87 Graduate
'65 101 Spider
I really miss my TR4A, and my 1800 ES
  #92 (permalink)
Old 02-24-2008, 08:53 PM
ascendedmaster ascendedmaster is offline
Headlight fairings
In my view a Spider looks incomplete without the headlight fairings & clearly this is what Pininfarina intended. Stock Carello items fit well enough with care and a little tweaking. I'm still looking for some smaller chrome trims to fit though.
My car. Regards, Ed.
  #93 (permalink)
Old 02-24-2008, 08:56 PM
oldschooleuros's Avatar
oldschooleuros oldschooleuros is offline
Nice Spider, looks very good with the fairings on it, and my favorite spider color of course.
  #94 (permalink)
Old 02-24-2008, 10:39 PM
brownie93's Avatar
brownie93 brownie93 is offline
Weaving a Spider's web
I hadn't seen the bubble covers on the S4 before but it looks good. Very nice.
93 and 94 Ce Spider
  #95 (permalink)
Old 02-25-2008, 11:06 AM
Zeno Zeno is offline
Hi ascendedmaster,
Your car looks great with those covers. What did you have to do to install them? Did you do any body work to fill in the gaps or did you just leave them open?
Thanks.
  #96 (permalink)
Old 02-25-2008, 12:09 PM
Garry-Graig's Avatar
Garry-Graig Garry-Graig is offline
I bought some aftermarket covers just in case my Carrellos got swiped,used it for 3 months and it cracked and perished because of the sun.I am sticking with the Carrellos regardless.
  #97 (permalink)
Old 02-25-2008, 03:00 PM
Headlight fairings
Dear Zeno,
You can fit the Carello items relatively easily. While the S4 does not have the two slots present in the upper part of the reshaped nacelles, they become unnecessary if you remove the two corresponding tabs on the fairings.
The fairings are located instead with self tapping ss screws into the headlamp brackets directly, and at the front by the stock brackets.
"Sealing " is not an issue. The small gap provides ventilation to prevent condensation as on all Spiders.
Regards, Ed.
  #98 (permalink)
Old 02-25-2008, 03:18 PM
So, are they that simple with S3 Spiders?
[COLOR="Green"]When cornering hard.... It's not the tires screaming...[/COLOR] [COLOR="Red"]It's the road begging for mercy. [/COLOR]
[COLOR="Red"]1985 Maserati[/COLOR][COLOR="Green"] Biturbo, 5spd. A work in progress. [/COLOR]
  #99 (permalink)
Old 02-25-2008, 04:13 PM
John M's Avatar
John M John M is offline
Alfa Poor in KY
Not easy at all old school. We have went through this discussion several times in the past. Do some searches and you'll find some better pictures of the defects with trying to install the covers on a series 3 or 4 spider. The correct installation has the covers laying flush on the opening all the away around the cover to metal mating surface. What happens with a series 4 or 3 nosed spider is that a quarter inch or more gap will be seen at and leading into the corners. Also, a series 3 or 4 spider has no provision for mounting the headlight behind the fender....hence the Biba kit. The red series 4 above has no trim ring on the headlight bucket. Biba's kit will correct this issue...but not the gap between the cover and the sheet metal. On series 2 spiders, the mounting studs and wheel well access panels are already there to mount the headlights behind the fender. Unfortunately, no one makes a cover to fit a series 3 or 4. So the only correct ways to do it would be 1. fab a cover or 2. reshape the sheet metal to fit current covers. The cover's tabs and their corresponding holes usually have to be cut on all US spiders.
Now with all that said....some people have gone the mile to do the body work and make it look stunning. No doubt it looks great done to the later spiders. And its a modification worth going the extra mile to make it fit and look perfect. I remember a yellow series 3 someone posted before and it looked extremely nice and well done.
Best Regards,
John M
  #100 (permalink)
Old 02-26-2008, 09:52 AM
sprintgtc sprintgtc is offline
I am in the process of making this mod to my '84 Spider. I have taken many pictures along the way and will do a full write-up as I get closer to the finish line. Be prepared to do the following:
1. It is possible to mount the headlights from behind, but it is labor intensive.
2. You will need to find a set of old-style headlight buckets in order to change headlight bulbs in the future.
3. You will have to repaint the nose of the car, so best to do as a part of a repaint/ resto.
Mike Macaulay
Seattle
84 Spider Veloce 69 GTV 66 Giulia Super 64 Giulia GTC 57 750b
  #101 (permalink)
Old 03-31-2008, 01:02 PM
Nicola's Avatar
Nicola Nicola is offline
(Un)protected species
Try this Daniel
bumped for das
I'd rather be in an Alfa praying to God that we'll make it home, than sitting in a church thinking about my Alfa.
Gordy Hyde
1974 Spider 2000 ~ "Mia" (Carb-free)
1971 Junior Zagato 1750 (1800605) ~ "Zach"
  #102 (permalink)
Old 03-31-2008, 07:58 PM
Anfanuts's Avatar
Anfanuts Anfanuts is offline
Certified Oldschooler
Best Regards,
John M
You know, Ferrari's use headlight covers with substantial chrome trim around the underside/paintside, like the photo of the S4 above. I thought it was reminiscent of a Ferrari and could be done well if you found some nice trim. I've had a NOS set in the cabinet since 1977 but have hesitated to install them for various reasons, one being that they just look unfinished. I could see doing that. Nice. Bruce
Anfanuts; Ph.A., B.S.A.
Now
- '69 1750 Spider Veloce (pictures)(and more) 10562.1480323 (since '75 for that early mid-life crisis!);
- '88 Bayliner, 305 CI Cvy (for those really hot days!)
Gone - '69 1750 Berlina (wish I still had)
