Old 05-12-2004, 12:18 PM
gotglasses gotglasses is offline
Screaming, Squealing noise at idle.
I got a shock this AM getting off highway, car was fine at speed . as soon as I take my foot off accelerator the car squeals in an ear shattering squeal. I checked clutch, brakes and fuel pump. It seems to be coming from inside the middle of the car. The only part I can think of is the Altitude compensator, but that never acted up before and must cost a fortune. How do I fix this cheaply?
Old 05-12-2004, 01:59 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
What year and model is your car? Have you checked for an alternator that's loose in it's mountings. With the engine off, grab it and try and shake it. It won't be obvious by just looking at it.
John Stewart
74 Spider
Old 05-12-2004, 02:04 PM
ossodiseppia's Avatar
pffffffffffffffffffffff!!
Never heard of one of them making a noise. But if you need one, I will scrounge one up for you.
Old 05-12-2004, 03:31 PM
Squeal
This is an 86 Quad Spider. the noise goes away when I blip the engine or accelerate, foot off the gas and noise starts. eery. Must be high vacuum related. sounds like brake squeal but it is not. Not coming from engine, this leaves me with the fuel pump - which seems at it's normal loud self. I have a fuel odor in the car , wonder if it could be from the carbon cannister? This is a part that I have never found, but am told it is in the fender.
Old 05-12-2004, 03:50 PM
Roadtrip's Avatar
74 Alfa Spider
Does sound like vacuum. Try disconnecting the line from the fuel vapor recovery system up in the engine and see if it goes away.
John Stewart
74 Spider
Old 05-12-2004, 06:38 PM
geh458's Avatar
geh458 geh458 is offline
Originally Posted by ossodiseppia
Never heard of one of them making a noise. ....
I wouldn't be the alternator making the noise, but the fan belt slipping on the pulley might be.
Gifford
'72 Super, '67 GTV --> SOLD
Old 05-12-2004, 06:52 PM
papajam's Avatar
papajam papajam is online now
with the Librarian
I've no personal experience with this but I've read that a vacuum sensor located behind the right seat by the ECU can emit this squealing sound.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 05-12-2004, 07:38 PM
Yes that was it.
Pulled the cover off the rear P/S , Altitude device squealing at idle. Took it off ( all nice and shiny, like new) and found a nasty, rusty piece that I had in my spare parts bucket (from another project car - never throw away the junk in the trunk ). Under the dirt it had the same part # - and it does not squeal after installing it.
Another amazing thing - my car ( and other Alfa in the past ) would not turn on the alternator after starting until I raced the engine slightly, the charge light stayed lit while it warmed up. Now, with this other altitude compensator , it immediately extinguishes the charge light when it starts!
This must have been a significant vacuum leak , wonder if it contributed to my recent emissions headache?
Thanks for the feedback guys!
Old 05-13-2004, 05:13 PM
You're the man , Papajam!
OOps - it is a vacuum sensor, not the altitude compensator which connects to the injection computer. This plugs into the ignition computer. I guess it acts like a vacuum advance on an ordinary distributor ignition. Anyway, it is quiet now and got rid of a vacuum leak by replacing the part. Are these still available as a new part?
Old 05-14-2004, 07:56 AM
Bill's Avatar
Bill Bill is offline
Mine does the same thing and has since I acquired the car. I replaced aternator a few months back (3rd one under warrenty from O'Rileys) but it did it before the original change and is still doing it. Once the engine is warm, no problem, But I have to race it at the start up to get the light to go out.
Is this a quirk in the charging system, bad batch of alternatiors or bad ground?
Get out there and DRIVE!!!
Bill
'78 Spider
Old 05-14-2004, 12:52 PM
I'd say a quirk since all 4 of my cars have done that, maybe a ground wire to the Alternator would help? Car needs a little surge on start up to turn on the alternator. My vacuum issue helped this but it is still there when cold.
Old 05-16-2004, 05:03 PM
papajam's Avatar
with the Librarian
Way to go, gotglasses! Just send GTV parts. J/K
I suspect that the alt light going out now at startup is because of a slight startup rpm change that has occured as a result of the vacuum leak being repaired. I base this on knowing that one can change the rpm at which the alt light goes out (and when the alt starts to charge the battery) by changing the bulbs wattage.
Old 05-16-2004, 07:01 PM
changing bulbs? getoutahere!! This I have to try.
I'm starting a new thread on my radio/ cigar lighter issues.
BTW - Ebay has a vacuum sensor for sale by the DeNoya Res. - They are calling it an Altitude compensator TOO!
