Old 02-16-2008, 02:01 AM
Campisi Campisi is offline
Alarming Oil Pressure
When driving along, my oil pressure gauge tends to split the difference between 57 and 114. When I gun it, however, sometimes it spikes up as high as what I imagine is ~110. Is this normal for these cars? If not, could this possibly be due to a faulty oil pressure sending unit (or whatever it's called), and if so how can I test it to see if it's in need of replacement?
1986 Spider Graduate
Old 02-16-2008, 02:39 AM
Zunige's Avatar
Zunige Zunige is offline
In the Spider's Nest
No, that is not normal. When the engine is running fast the maximum is supposed to be 65-70 psi, and the minimum 50. (When a fully warmed up engine is idling the pressure drops a lot, but it should not go below 7 psi.) You could check your pressure with a mechanical gauge... There are quite a few threads on this subject, so I would suggest you do an "advanced search" looking "oil pressure" in the thread titles only (otherwise you'll get way too many threads.)
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 02-16-2008, 09:16 AM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
My bet is a failing sending unit, but first make sure the wire from the sending unit to the dash gauge is connected correctly and not obviously damaged. If you have an mechanical oil pressure gauge and fitting, you can double check it. If not, it may be just as cheap to just replace the sending unit and see what you get rather than buy a mechanical gauge.
John Stewart
74 Spider
Old 02-17-2008, 08:48 AM
besposito's Avatar
besposito besposito is offline
I second the vote on the sending unit. Alfa oil gauges are notoriously problematic.
Old 02-17-2008, 05:40 PM
John M's Avatar
John M John M is offline
Alfa Poor in KY
Since no one has said it, might also be a sticking relief valve in the oil pump. If this is happening frequently enough to check and catch it with a mechanical gauge, then do so. If its really doing it, rebuild your oil pump.
Best Regards,
John M
1978 AR Spider Veloce 2000....the first and still here
1978 AR Spider Veloce 2000...soon to arrive, its black and its slow!
Old 02-20-2008, 07:57 PM
This is actually what I'm expecting the problem to be. Sometimes, if for whatever reason I get the RPMs up within a grand or so of the redline and then back off the throttle, the oil pressure snaps to about fifty or so for a bit before coming back to a hundred. I don't have a mechanical oil pressure gauge available to me, so I've just been nursing it and not driving it much while I wait on a new sender (which I'm still hoping is the problem).
Old 02-20-2008, 10:36 PM
davelgee davelgee is offline
A short or sender/guage problem is pretty likely IMHO, my OP read between 57/110 (and jumped back and forth) when I first put the motor back in and did the paint.
Turned out to be a wiper apron/rear hood rubber screw (first one to the right of the hood latch) that had invaded the wiring just a tiny bit.
Cheers!
Dave G.
Old 02-21-2008, 04:41 PM
oldschooleuros's Avatar
oldschooleuros oldschooleuros is offline
Get a new send unit and external gauge and see what she says after that.
