Old 01-17-2008, 11:02 PM
loudsoundguy loudsoundguy is offline
Question Setup for "DINGY" towing a '83 Spider ??
I have a "83 spider, and am wondering if anyone has setup a tow bar bracket
on a Spyder chassis??
1) Is it safe to tow a Spider with a tow bar? (four wheels on the ground)
2) Has anyone done this?
3) Any idea where to get brackets for a Spider??? (got the tow bar already
Thanks for your help, LSG
Old 01-18-2008, 04:27 AM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
I never have, but I just wanted to mention that whatever you do, note that the "U" hooks underneath the bumper are not to be used as towing points. They are not affixed to anything that will withstand the weight of the car. They are meant to be used to secure a car when it is being transported flat, and this assumes that the back hooks are also being used.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 01-18-2008, 09:04 AM
azmaynard azmaynard is offline
I posted a similar question several months ago, I needed to tow a 73 Spider about 500 miles. There were no useful answers and now that I am more familiar with the car I can see why. There is nothing that you would feel confident hooking a tow bar to on the older spiders, newer models may be different due to heavier structure to comply with DOT bumper standards.
I ended up renting a car dolly, it worked great.
Maynard
Maynard Kreps
73 Spider
98 Ducati ST2
76 Moto Guzzi T3 (V7 Sportized)
97 Nissan Pickup
Old 01-18-2008, 10:44 AM
conedriver's Avatar
conedriver conedriver is offline
George Schweikle
Lots of people tow cars behind Motorhomes. "Flat towing" is done with a strong tow bar, and a "base plate" that attaches to the car with connection points for the tow bar. Get on the internet, and you might find a company that makes an arrangement for your spider. I parked next to a motorhome at the Manchester New Hampshire AROC convention, and he had such an arrangement for a spider. I didn't see if it was a commercial product or home made...Try this site for tow bar info: Blue Ox Products Home Page
Years ago, many people flat towed their race cars. Common wisdom at the time was to disconnect the driveshaft for extended towing.
Almost forgot. Almost all states now require supplemental braking systems on "Trailers" weighing over 2000 lb. Your flat towed spider will fall under this requirement and require a braking system to be completely legal. Check your state laws.
George Schweikle
Scuderia Non Originale
Old 01-18-2008, 03:26 PM
Geezer's Avatar
Geezer Geezer is offline
The advise to remove the driveshaft is GOOD advise. The reason being is that the driveshaft will be spinning the mainshaft in the trans. That shaft is above the oil and thus will burn itself up due to lack of lube. Some folks will advise stopping every 200 miles or so and let the engine run so the oil will be circulated through the trans. BAD ADVISE. By then the damage is already done.
Removing the driveshaft applies even when using a 2 wheel dolly with the rear wheels on the road.
Larry the Cable Guy
Old 04-23-2008, 12:31 PM
retiredbu retiredbu is offline
Towing Spider
So I looked at a number of posts and came up with as many opinions. Did you try it? How did you hook to the Alfa?
Old 04-23-2008, 01:32 PM
SpiderWebb's Avatar
SpiderWebb SpiderWebb is offline
Wow! It's pure logic. Of course, the oil is only on the lower shaft and gears. Oil is drawn up when the engine is running and you are going through the gears. While being towed, out of gear, the top shaft will not get oiled! Yikes!
In a related way, it kind of makes a case for engine braking down a mountain instead of coasting out of gear and using only your brakes. Not likely I know. But, on a light traffic day down a tall mountain, like the San Gabriel Mountain range (aprox. 10,000'), you can coast a LONG way without ever touching your gas pedal and need for a gear.
A recent pleasant discovery with my spider was the ability to stay in 4th gear (3rd on uphill) a long way down the mountain from Idylwild. The car is so light it never gained much momentum and I don't know if I ever touched the brakes through much of that road. Our big fat Dodge Durango would have burned up an automatic transmission band and smoked the brakes on the same run.
1981 Spider 2000 USA - It's SpiderWebb cuz' Webb's my last name.
