Against my better judgement I have begun the trek of discovery into the sills of my RHD '67.
I removed the LH front splash guard at the rear of the wheelwell and dutifully removed about a pint of dirt and rusted metal ! My intention is to clean out both ends of both sills, determine the damage, then if it's not too bad I'll spray in some preventative goo (fishoil) and start saving $$ for repairs.
So far the front of the lower sill looks pretty bad, at least what's left of it, but the rest of the metal in the area looks remarkably good. I suspect that the sill centre sections were replaced at some time, but the ends are now in need of attention, mainly from POs efforts to seal the splashguards. All this achieved is to create a moisture and dirt trap.
So, I would like to cut a few holes in the top of the sills for inspection, cleaning and treating purposes. I have a diagram of the X-section of a sill (
http://www.alfaparts.net/105_115sill.htm#) but am wondering if anyone knows the location of the 'gussets' welded into the inner sill ? I am thinking of cutting a 1" dia hole at both ends of the inboard sill (marked 2 in the pic below) and possibly some smaller holes in the outboard portion (marked 1 in pic below). I will blank the holes with glued-in grommets and the evidence will be covered by the sill trim.
What I don't want to do is cut into any of the gussets.
Comments are welcome on the stupidity of my plan and I will upload pics of the rusty areas to the site in the signature block below.
