04-02-2008, 11:23 PM
Herb 22 Have you recently checked tire pressure, front and back ? Meaning factory recomended tire pressure ,
04-03-2008, 09:28 AM
In the Spiders' nest...
Originally Posted by usatrade
... Have you recently checked tire pressure, front and back ? Meaning factory recomended tire pressure ,
The recommended tire pressures, as in the ones found on the inside glove box door, are out-of-date for modern tires. The tires we use today are supposed to be run at higher pressures, and there are several advantages to this, which have been highlighted in many threads on the BB...
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
04-03-2008, 11:19 AM
Please keep the factory rire pressure ! It is safer and much more comfortable.
You do not need higher tire pressure for the snail speed we drive in the USA. 65 miles an hour is barely 3rd gear speed !
In France with speed limit of nearly 90 OK, in Spain where speed limit is about 70 MPH but nobody bothers you much on (expensive) freeways until 100 or so MPH, in Germany where most freeways have no speed limits.
But here it is a joke !
When I see people on the freeway accelerating to 80 and thinking they are going flat out it's funny.
Believe me keep the original tire pressure until you are on the race track.
Claude
406 automobiles, from Isetta to GTO Ferrari and 427 Cobra and 26 Alfas.
04-03-2008, 12:27 PM
Checked the steering box adjustment. Seems OK. Have not looked into it further. Just living with it. Someone recommended the trailing arm bushings since they are 18 years old. That's probably first.
04-03-2008, 01:55 PM
Claude
Claude,
I'm going to state as politely and respectfully as possible that your advice regarding tire pressures and modern tires sold in the U.S. is truly outdated... (And I'm not referring to driving speeds in different countries. I actually enjoy reading about such differences.) Anyway, I'm not going to hijack this thread or engage in a debate here (there are plenty of on-topic threads on the BB), but I do think it is important to state so, for the sake of Spider owners who may be reading this thread...
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
04-03-2008, 02:42 PM
Dear Zunige
We have installed brand new Pirelli's (185) on the spider (88) and with 30/32 pounds of air pressure the car is all over the road. back at normal pressures the car handles the way it should. I also have brand new Goodyears (185) on the other spider (79) and the result is the same.
What is your theory to say taht tese tire pressures are outdated ?
Claude
04-03-2008, 04:08 PM
Claude,
I can assure you that running 30/32 psi in your tires is not the reason why your Spider is all over the road... Something else is off, and lowering the tire pressure is simply camouflaging the problem, but so as not to hijack this thread, below are some of the BB threads regarding tires, and pressure, where we could continue this discussion. Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
04-03-2008, 04:25 PM
Sorry but this is not "camouflaging" the situatiuon; The 88 spider has a brand new (total) front end. My son (it is his car) then went to have the new Pirelli's installed and the shop put the tire pressure (too high). My son (first Alfa) then ran back to the mechanic thinking something was wrong with the front end of the car. The tire pressure was put back to normal and all was fine. The mechanic is a highly knowledgeable man, like many Alfisti would like to have around them.
I will stop here but I do not see what has changed in the Spider with the Pirelli's then and now ? There is NO reason whatsoever to change the tires' pressure...unlass you load or overload the car.
Claude
04-03-2008, 04:38 PM
Just read all that stuff. 90% is about the looks of the tires and 10 % in favor of proper (factory) pressure.
Claude
