Old 11-05-2007, 11:50 AM
cargaritaville cargaritaville is offline
93 Spider Veloce Intermittent No Run
I've got a 93 Spider Veloce with intermittent no run. We always have fuel and injector control we do not have spark when this problem occurs. The coil has the correct resistance and can be made to fire. What would the next most likely repair item be to fail? Any help would be greatly appreciated.
Old 11-06-2007, 08:10 AM
Advice? Please. Bump.
Old 11-06-2007, 01:48 PM
alfaloco alfaloco is offline
These cars need well above 11 volts to start and run. How's the battery? Grounds? What about the main ground in the trunk floor? Loose battery post? Corroded posts or terminals? Sounds like primary electrical source to me. If this checks out, I would next look at the main Motronic relay under the panel behind the seats. If you need to know which relay this is, I'll check into my manual and notes this evening after I get home.
Dave Jarman
Lexington, KY
USA
'91 Spider (red)
'94 Spider CE (yellow)
Old 11-06-2007, 02:26 PM
dghii dghii is offline
Ignition switches are know to go bad in Alfas....
[FONT="Microsoft Sans Serif"]Don - 1984 Spider Veloce[/FONT]
Old 11-07-2007, 08:46 AM
Dave-- Thanks for the help! The volts are okay. The relay we will check next.
Old 11-07-2007, 06:32 PM
ocduff's Avatar
ocduff ocduff is offline
Cargarita -
Are you getting spark at the plugs too? How are the dist. cap and rotor? All plugs are good? Reistances of plug leads good?
check ground wires, check battery connections, check relays under the rear bench, check fuses in the box, as well as relays.
I've been where you are before, and it sucks. you'll figure it out, but there's nothing worse than an intermittent problem.
