View Poll Results: Which is better?
The Stock Ignition.
6 |
40.00% |
MSD 7AL-2, even with its price...
3 |
20.00% |
Jacobs Pro-Street Kit, just 15mj shy of the MSD, but is digital!
6 |
40.00% |
10-06-2007, 09:38 AM
Alfa Poor in KY
Originally Posted by gt601
I had a 6-AL on my old GTV-6 when I got it. I could never seem to get it to run the way it should of.(the way I thought it should run) I could never get the timing set right. I tried all sorts of things  I advanced, retarded, etc.
Changed wires,cap,plugs,rotor. It seemed to run out of power too soon and didn't idle too well. (Of course the Shankle EG rally grind on the cams made it sound like a drag car at idle. The HC at idle were around 4000 ppm  The engine seemed to fall on its face at around 7 grand.
Long story short. I finally called some one at MSD. The guy I spoke to was very sharp. He says the MSD has TOO much spark for the Small Alfa dizzy cap. It was jumping spark across the inside of the cap causing spark to reach cylinders that weren't ready for spark. I went back to the OE set up using the MSD Blaster coil. The Idle improved, the HC at idle dropped to 2900ppm. (The cams  )
The engine was able to pull hard at over 8000 rpm (had it to 9400 at an auto-x once. Oops)
I would install the Jacobs if I had a choice.I installed one on a buddys Toyota truck and it made a world of difference. Power, mileage,etc improved.
I think Jacobs is more modern and up to date.
JMO
Paul
To Paul:
I, like Erik, have been running the MSD 6AL for several years. I think it was probably just the box malfunctioning Paul. Erik and I are proof of that. I have had it triggered off the points distributor as well as the LED RML unit. The MSD guy looking to blame the car rather than his box.
To Mark:
Come on up then!!!!
To Erik:
Check out these. I wonder if the difference is from the stock system falling off at upper rpms. What do you think?
http://www.grmotorsports.com/backissues/mg-dyno.php
http://www.4x4wire.com/toyota/reviews/jacobs/
Best Regards,
John M
10-06-2007, 09:42 AM
Originally Posted by genericwood
David, we agree that more of a good thing isn't necessarily good when it comes to ignition advance. But I would argue that the same logic applies to most people putting the latest, hottest electronic ignition system on their car.
Erik
Touche'! You nailed that one! Though, not being argumentative, I don't have the latest one, I specifically went out and found an original Jacobs Pro Street. The latest ones being made now don't have the features and Mr Gasket cut even more corners as far as quality.
 1990 Alfa Camaro Spider Super Sport Special American/Italian Edition. Pizza Burner with Pizzaz!
1974 Chevrolet Camaro
10-06-2007, 09:47 AM
Paul, let's just say that the guy you talked to wasn't very sharp. There are hundreds of 6AL's in use on Alfas around the world providing good service. Sure, the MSD box you had might well have gone bad. But there is nothing incompatible with the MSD and the Alfa ignition. The MSD tech should know this.
Erik
That actually is a very common problem that is listed on their tech forums at MSD, smaller distributor caps *can* cause arc over inside the cap. What I like about the jacobs system (amongst the many of things) is that the spark is controlled, hotter spark as engine load increases, full throttle switch to engage the systems full output, etc...
10-06-2007, 10:20 AM
Originally Posted by John M
To Paul:
It is clear something was wrong, but he did say he had a V6, not a 4 banger like us. All is possible, it hurts to even ponder it all...
I love how that first link actually made refernce to the design of the head and advancing the timing were related. That is usually over looked, a more turbulent head hates advancing, but loves and uses more volts to fire the plug under load. That is more than likely why they got such a good gain in power with the electronic set up-hotter spark to go along with a turbulent head.
10-06-2007, 10:53 AM
I sold it to a VW guy for his drag car for 25.00 and it worked flawlessly on his car. Just the wrong application.
Paul
The meek shall inherit the rear view mirror.
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
79 Alfetta GTV(smooshed and ground up)
10-06-2007, 11:11 AM
Paul
Could you post your avatar in full view??? I can't make it out-looks like squirrels having a battle to the death with foam noodles...
10-06-2007, 11:21 AM
Darkside Member
Looks like squirrels fighting with Star Wars lightsavers.
10-06-2007, 11:31 AM
OK, is Enrique Darth Vader and you're Luke or what...Apparantly I was being drafted to the "dark side" (black spider-whatever), I just want to know the roles we're in...lol
BTW-Light Sabers.
10-06-2007, 12:26 PM
Squirrels??? Don't see it.
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
10-06-2007, 12:28 PM
Sorry... I changed it back to a more "Alfa BB correct" avatar.
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
10-06-2007, 01:20 PM
FORZA ASSERGI
David,
Could you explain what sort of performance gains your expecting over the stock Motronic ignition that came with your car?
Ciao tutti
Newly retired so, Non mi rompere i coglioni.
93 spider (red)
87 milano (not red)
10-06-2007, 09:13 PM
Originally Posted by aldo
David,
Hmmm, maybe the need for LESS tailwind...
10-06-2007, 09:14 PM
