'89 Spider Radiator Replacement Probs.
OK, seems minor, but what the hell do I know?
Alternator pivot bolt came loose on the '89 Quad, crept forward into the cooling fan. Fortunately, it was at idle, so no damage other than three blades shredded.
Struggled to remove the radiator, after first detaching the shroud. Now struggling to get the radiator back in, past the shroud, because it looks as though the shroud has to be in place around the fan first, then re-attached to the radiator. Right??
Any suggestions? Can the radiator be put back with the shroud attached? Is this a two man job?
Sheesh...
Mark
'67 Super
'89 Spider Quad
'67 GTV (years ago)
'50 XK120 (years ago)
