#16 (permalink)
Old 06-27-2007, 07:18 AM
frieddoh's Avatar
frieddoh frieddoh is offline
4*Foglio
Send a message via AIM to frieddoh Send a message via Yahoo to frieddoh
I have an Optima battery in my 164... same cranking power as the original and in a smaller size. The model I'm running is actually a boat battery that I got for less than usual because opportunity knocked. Have had for over a couple years now, never a problem. When the Interstate dies in my spider I'll probably replace it with an Optima. The main quality I look for in a battery is reliability... not liking the concept of being stuck somewhere because of a premature death. You do have to take into account the fact that batteries are consumables and you will eventually be replacing whatever you plunk down your spare (?) Alfa Dollars on.
Dan
'86 Spider Quadrifoglio
'91 164B
  #17 (permalink)
Old 07-16-2008, 02:05 PM
Peter's Avatar
Peter Peter is online now
AlfaBB Addict
I just had a Kirkland die in my wife's Jeep....bought it in January this year. I don't think I have a receipt anymore, but it is clear from the battery when it was taken into service, do y'all think that's going to be an issue with the warranty entitlement?
Peter
Currently:
'69 Euro 1750 GTV
Previously:
  #18 (permalink)
Old 07-16-2008, 04:28 PM
BradH's Avatar
BradH BradH is offline
Costco is usually really good about that, They can look into your record and see that you bought it. I would be surprised if you have any problems
73 Red Spider......
  #19 (permalink)
Old 07-16-2008, 06:13 PM
RandallM's Avatar
RandallM RandallM is offline
Yes I am someone that recommends and uses Optimas. I have Optima in my vehicle and my wifes car. I had one in her last car too. I will soon get one in the Alfa.
I have never had a problem with the Optimas and the best thing about them is they do not leak. I believe they are a dry cell technology. The only rust in my spider was in the spare tire well caused by a leaking battery from the PO.
In my 4x4 I have cracked the original battery and two Die Hards from the off-road poundings. Yet, the Optima has lasted 6 years.
No, I do not work for them, but am an unpaid actor.
Randall
86 Spider (Slick)
  #20 (permalink)
Old 07-16-2008, 07:14 PM
flaatr's Avatar
flaatr flaatr is offline
Originally Posted by peglegtom View Post
I just have one question. How many people that recommend Optima batteries actually have one in their car? I suspect that most wish they have one in their car but won't pay the price themselves.
I recomend them...
and I do in my '87!!!
BTW, my '80 Scirocco came from the previous owner with a new Kirkland (Cosco) battery and I said to myself, "Myself, that's got to go"... now three years later it's still in there and it works fine*. I'll replace it when I can figure out how to get a Varta battery in the states!!!
The Alfa will get one when I get around to doing the relocation to the back... 'till then what it's got is fine
-Raffi
* I keep all my cars, except my daily driver connected to battery tenders so there is no chance discharge, deep cycle or otherwise.
[SIZE="1"]-1974 Alfa Romeo Spider (still working on it)
-1980 Volkswagen Scirocco (Bone stock & original, 51K miles...)
-1987 Volkswagen Scirocco 16V (2.0L, Nothing stock or original)
-2003 Volkswagen Jetta TDI (Saves me money for the above)[/SIZE]
  #21 (permalink)
Old 07-16-2008, 08:01 PM
sunsprit sunsprit is offline
As a Denver area automotive shop, I was selected as a "beta test" center for the Optima batteries when Gates was developing them. I sold and installed many in my MB Diesel customer's cars, and some of them are still in service ... now over twenty years!
Since I had access to Optima cosmetic "blem" batteries at significantly reduced pricing, I installed them in all my cars and trucks. I have one in my '72 BMW 2002 that's been in service for 15 years, and the car is infrequently driven.
The big difference between an Optima and a conventional wet battery is the ability to handle charge/discharge cycles. The Optima will deliver more amps and maintain higher cranking voltage for better starts compared to most batteries, but the standard Optima battery will not tolerate many complete discharge cycles as a wet lead acid battery can. So, if you have a car that isn't driven frequently enough to keep up with the parasitic electrical loads, a standard Optima isn't the battery for your car unless you keep it on a battery maintainer. Similarly, if you are prone to leaving a door ajar or dome lights on, you'll have a dead Optima battery and greatly shortened service life ... maybe 5-7 cycles.
Optima tackled this cycle problem with their "deep discharge" version intended for marine use, where it is customary to run a battery well down between charging cycles. But it's a lot more expensive than the standard and not worth the expense in a normal car application.
Now, in my wife's cars and trucks, more recently acquired ... we run Costco batteries and have never had to replace one yet in 7 years. This will probably be the summer when her car battery will finally fail, and we'll replace it for cheap.
  #22 (permalink)
Old 07-17-2008, 11:18 AM
flaatr's Avatar
Do you have my mailing address???
I like "significantly reduced pricing"
-Raffi
  #23 (permalink)
Old 07-17-2008, 12:48 PM
lowmileage's Avatar
ReAlfisted 3/06
Those bad boys are wayy heavy though for an Alfa especially if they aren't trunk mounted IMO. Cosco batteries, while not as economically priced as they once were, are what I buy. 3 year full replacement. Put a new one in my wife's extreamly non-DD cause the one in there was 7 years old. Just for piece of mind. I'll keep the old as a spare. One thing though, they use to have dual terminals but on the new one they don't.
They will pro rate your battery by the date on the case. I doubt you'll need a receipt. Cosco will take most anything back without a gripe.
1973 GTV - bought 3/06
1969 GTV - sold 10/72
"I've shot 630 elephants and 63 men, and I regret the elephants more." Arthur Jones.
  #24 (permalink)
Old 07-17-2008, 03:21 PM
flaatr's Avatar
Funny thing is the Yellow Top "deep cycle" batteries only have a 2 year warranty were the Red Top has a 4 year. The first year on both is Free Replacement. Even if you deep cycle the Red Top you can get it replaced longer than a well cared for Yellow Top.
That's how my mind works.
-Raffi
  #25 (permalink)
Old 07-17-2008, 04:15 PM
RandallM's Avatar
I just looked at the original posting, and in New England you do not have the excessive heat we in the deep South have. Batteries last much longer in cooler climates and the Costco probably works excellent there.
Randall
86 Spider (Slick)
  #26 (permalink)
Old 07-17-2008, 06:09 PM
Right! Down here, better get rid of whatever you have after 3 yrs......even if its still "good". A 3 yr will only last about that, and you dont want to be stuck anywhere when it dies (although, usually easy to jump start).
Also, Sams is good source.......
  #27 (permalink)
Old 07-18-2008, 07:00 AM
Peter's Avatar
AlfaBB Addict
got mine replaced without a problem
Peter
Currently:
'69 Euro 1750 GTV
Previously:
