02-27-2004, 10:32 PM
74 Alfa Spider
Replacing a Burman Shaft-Type Steering Box Seal In-Situ
Hope this helps some people replace the seals in their steering boxes. I think there's a lot of dry steering mechanism running around grinding themselves to pieces.
Est. time 4 hrs, perhaps longer if cleaning/painting parts.
It is fairly easy to replace a lower seal on a Burman steering box . The steering box does not need to come out of the car. The Burman steering box is stunningly simple, very robust, and has very few moving parts. Before starting, read this entire procedure and understand it, including the nomenclature of parts. Reference you repair manuals for exploded diagrams.
Parts required:
1. Oil seal. Just about any commonly available 28mm ID x 40mm OD x 7mm height seal will work.
The seal I used: CR Chicago Rawhide, Stock # 10939 28x40x07 HMS4 R obtained at a local bearing store. I ordered one from ARRICAMBI, but the one they sent was the wrong size.
Special tools required:
1. 32mm socket for removing the lower bolt from the rocker shaft. If you don’t have a 32mm, a 1¼” socket works just as well and is within a quarter millimeter of 32mm.
2. Sturdy breaker bar, preferably at least 1/2” drive with extension.
3. A strong 2-arm gear puller
4. Torque wrench
5. Andrea Bocelli "Cielo de Tuscano" followed by John Cougar Mellancamp on CD
Discussion:
1. The night before you do the work, I would recommend that you put some high quality penetrating oil on the upper part of the steering drop arm and rocker shaft. It is likely that these parts are corroded together somewhat and will be difficult to separate.
2. Put car securely up on jackstands. You will be exerting considerable force getting the rocker shaft nut loose and again torqueing it to specification, so the car need to be rock stable.
3. Recommend removing the exhaust downpipes and front resonator for more working room.
4. Center the wheels.
5. Mark steering drop arm to index it with the rocker shaft. You want to reinstall the drop arm in the same relative position to the shaft.
6. Remove cotter pin
7. Use the 32mm (1 1/4") socket and breaker bar to loosen the rocker shaft bolt. Remove it completely and clean the threads. Loosely replace the bolt on the end of the shaft so that the steering drop arm won’t come flying off the shaft should it pop under tension. This bolt is torqued to about 100 ft/lbs, so it’ll be fairly hard to turn. Lock the steering wheel so it won’t turn.
8. Use the 2 arm gear puller to extract the drop arm off the rocker shaft splines. This will likely require considerable force on the part of the puller. It must be of high quality. If the drop arm won’t budge, give the end of the puller screw a sharp hit to break the corrosion. Be prepared for a “pop.” If it still won't budge, put some more penetrating oil on it and leave it under tension with the gear puller overnight and try again in the morning.
9. Remove the bolt and extract the drop arm from the shaft. There is no need to disconnect the tie rod ends from the steering drop arm. You may have to turn the wheels slightly to the right to have the end of the drop arm clear the left suspension. This isn’t a problem because you’ve already marked the shaft and drop arm to their relative positions. Take hold of the shaft and see if you can feel any lateral play (wear) in the bushing. If so, the box may need a new bushing reamed. Replacing a seal in a shaft with worn bushings will probably leak again.
10. If the steering box still has oil in it, place a bucket under the steering box.
11. Working in the engine compartment now, remove the small oval cover on the top of the steering box. This cover is under slight tension from a short spring underneath. Remove the cover along with the shims underneath.
12. Remove the entire top plate of the steering box. The left side bolts are in blind holes, and the right side bolts have nuts and lock-washers underneath. The top cover is not under tension and will just lift off.
13. The inside of the steering box is now revealed. Note and mark the position of the rocker shaft in the box. You will want to return it to this position again for reinstalling the drop arm later. Next, turn the steering wheel so the rocker shaft is at the FRONT of the box. You may be able to get the rocker shaft out with it in the middle position, but I found it easier with it in the front of the box.
14. Pull up on the rocker shaft and remove from the steering box. It may take a bit of twisting and slight rotation to extract the shaft, but it will come out. The main nut roller will likely be dislodged when you do this so be prepared to capture it before it falls into the lower part of the box. Stuffing some small rags or paper towels will help capture it. If it does fall down into the box, it should be easy to retrieve.
15. With the rocker shaft out of the box, get back underneath the car and pry out the old oil seal. An ordinary screwdriver or purpose built seal extractor both work well.
16. Clean out the cavity. Inspect the bronze bushing in the steering box body for wear or damage. Ensure that the bottom of the bushing is flush with the bottom of the boss. If not carefully tap it back up into place.
17. Hopefully the steering box is clean inside. If not, it’s wise to clean it out while the lower seal is out. Inspect the case casting for any cracks. I'll be easiest to see them from inside the box. Look especially closely at the rear of the box where the steering shaft enters.
18. Install the new seal. Hand fit it square into the boss, then squarely tap it into place. The flat end of the 32mm socket works well. Just insert the extension bar backwards in socket and tap the seal into place.
19. Clean and inspect the rocker shaft. There might me some corrosion right around where the lower oil seal contacts the shaft. Clean well and polish with a little metal polish so the surface is as smooth as practical. If it’s badly corroded, you may get a leak even with a new seal. A good machine shop can likely fix a corroded shaft either with machining or installing a sleeve. If this is the case, you might need to get another seal with a different inside diameter size.
Reassembly:
1. Grease the rocker shaft in the area where it contacts the bushing and lower seal lip. Carefully lower the shaft back into the box body. Line up the steering nut and hole in the upper shaft arm. Grease and replace the main nut roller in the hole in the upper shaft arm.
2. Turn the steering wheel back to line up the rocker shaft to the original index marks you made in the top of the box. This will put the steering box back in the same position as when you removed the drop arm below.
3. Replace the top cover. Cut a new gasket if necessary. Torque bolts to 16.6 to 18 ft/lbs.
4. Replace the small oval cover along with the shims and the short spring. To start the bolts, you may have to push down on the cover slightly.
5. Refill the steering box with a little 90w GL-5 gear oil and check for leaks at the bottom. If no leaks, refill the box. Replace the filler plug. If your filler plug is missing, get one. Any local auto store should have one that can be made to fit. Do not leave it open or the steering box will become contaminated with dirt and moisture.
6. Back underneath the car, replace the drop arm being careful to line up your previously made index marks. Using some anti-seize compound will make it easier to remove, if necessary, in the future. Reinstall the large castiliated nut. Before torqueing, place a chunk of wood between the drop arm and the left steering stop. This will take the torque of the tightening process instead of transferring it to the steering mechanism. Torque to 90.4 – 101.2 ft/lbs. At the same time, line up the holes for the cotter pin. It is necessary to use a new cotter pin unless the old one is in excellent condition. As all steering parts, this is a safety item.
7. Turn steering wheel stop to stop and check for normal operation. Check to ensure that you’re able to turn the wheel so that the steering linkages under the car hit both the right and left steering stops without reaching the internal steering box limits. There should be no need to realign the front end of the car since no steering geometry was changed.
8. As an ancillary item, check the tightness of the steering box to chassis bolts. Also check for any sheetmetal cracks where the steering box attaches to the body.
END
John Stewart
74 Spider
02-27-2004, 10:33 PM
74 Alfa Spider
Gear Puller on Steering Drop Arm
John Stewart
74 Spider
02-27-2004, 10:34 PM
74 Alfa Spider
Rocker Shaft Seal
John Stewart
74 Spider
02-27-2004, 10:35 PM
74 Alfa Spider
Internal view of steering box from top.
John Stewart
74 Spider
02-27-2004, 10:36 PM
74 Alfa Spider
Top of box with rocker shaft removed. Steering wheel has been rotated to put the "main nut" in the forward most position. I found this easiest to extract the rocker shaft. Still required a little wriggling.
John Stewart
74 Spider
02-27-2004, 10:37 PM
74 Alfa Spider
Removing the old seal with screwdriver.
John Stewart
74 Spider
02-27-2004, 10:39 PM
74 Alfa Spider
Oil seal boss with seal removed. If bronze bushing has pushed itself out a little, tap it back into the top of its bore.
John Stewart
74 Spider
02-29-2004, 07:17 PM
Roadtrip - my hat's off to ya' That was some writeup.
If I were to add anything it would be to look for cracks where the steering shaft enters the box. That's where mine exploded and it was obvious that it had been cracked for some time. There were no cracks in the box mounting section but, as I've been told from some of the experts, the way the box is mounted allows for a considerable amount of flexing which twists it's position and develops the cracks I experienced. I'm pretty sure that all of the oil had completely drained out of my box probably somewhere around 1973 or so. I ended up replacing it with a newer ZF box because just about all of the Burmans are worn out. There's that one sweet spot on the cam that gets the lions share of wear right around the center position and it causes centerplay that can't be eliminated without getting it rebuilt (requires machine work). The ZF box is entirely different inside but comes with it's own set of problems (including all of the oil draining out) With the ZF you can get a fairly new unit. I just filled mine with grease.
I also fabricated and installed a steel backing plate between the box and the frame. It matches the steel plate on the xterior for the chassis stiffener and so I do not get any steering box flex at all anymore. It has worked out really well.
Again - good job on the tech write-up. I'm sure it will help a lot of people out.
Paul Irvine
Project Alfa - http://vintage-air.home.comcast.net
02-29-2004, 09:13 PM
74 Alfa Spider
Paul - Thanks for the suggestions. I made the changes to the text. I thought about using grease in the box but since it has a new seal, hopefully it'll be good for many years now. I've found that grease that's left static will also turn watery sometimes and leak. At least it does in my greasegun. I have to wrap it in plastic to keep it from making a mess.
I'll bet a lot of boxes have been ruined by lack of lubrication. I suspect they'll last virtually forever if they're maintained correctly.
John Stewart
74 Spider
03-01-2004, 09:10 PM
John, nice write up! I did the job last year on my GTV. The only comments I would make are that many people will be able to do the job in significantly less than 4 hours. I was done in less than 2. And that I didn't find the need to remove any of the exhaust. I have always been baffled by the recommendation to fill the box with grease. It's just too easy to fix it right!
Erik
03-01-2004, 09:38 PM
74 Alfa Spider
4 hours is probably long, but I was factoring in extra time for stuck drop arms, a bit of cleaning, gasket making, exhaust pipe, etc.
John Stewart
74 Spider
11-17-2004, 09:01 AM
Just a bit of FYI, I tried to use a 4" 2-arm gear puller rated at 2 tons on my drop arm. I broke the tooth out of one side of the puller before the arm would budge (this after WD 40 overnight). I would recommend at least a 6", 5 ton puller (or a stick of dynamite) for your project.
11-17-2004, 10:28 AM
Just my experience;
WD40 is named for what it is, the fourtieth formula developed for Water Displacement purposes. That it's become a general "works for everything" solution is sometimes a negative. Many mechanics utilize much more effective penetrants such as PTBlaster, Liquid Wrench and my preferance, Kano Kroil. These will do a superior job assisting in freeing rusted mechanical components, than will WD40.
Regarding removal of heavy, well frozen parts, such as a pitman arm: careful application of heat combined with vibration by judicious hammer blows or impact hammer will prevent damage to tools and knuckles!
Alfista Sapien
11-19-2004, 06:05 AM
I would second the comments regarding WD40. This and duct tape are my favorite tools but they have their limitations. I can attest to the performance of PB Blaster as far supperior to WD40 for the tough stuff. I just R&R'd the steering box and the getting the pitman arm off was next to impossible without PB.
- Rich D.
