Paradiso,
Thanks for the suggestion. Actually, I did search the list and internet for about 3+ hrs before posting my question (slow dial-up connection) and did read B. Morgans post and reviewed Han's excellent website, both are very useful.
Still, I haven't found a source for the pulleys alone (maybe try to find salvage pieces) and I don't quite follow the adjustment procedure (just adjust the cable tension or the window position?). Also, how does the cable attach to the drum and does the cable need lubrication or better dry?
Rereading Han's site I understand that the cable he installed has 2 ends that come together at the window clamp (do you need to put a split bolt & nut on the cable ends to keep them from slipping out of the clamp?). Also, if keeping the existing cable, can the cable be reinstalled by just loosening the upper tension adjusting pulley?
Maybe these will become clear when I dive into it. I'm a little aprehensive because the car is stuck outside at the moment in the elements. I'll probably wait until I can pull her into the garage.
Pat
