Old 01-21-2004, 02:52 AM
jamieandthemagi jamieandthemagi is offline
105 series Diff/Prop/rear axle fault
During the summer before I took the spider off the road, it had a really noisy fault. Which I need help in trying to identify.
It only occured when the car was warmed up.
when pulling away in 1st, 2nd or Reverse, there would be a loud knocking / rattling noise from the rear of the car. This would only happen if the car was not pulling away dead straight - ie. if I kept the car in a dead straight line, it would not do this.
Last night I had a quick look under the car. The intermidiate bearing looks OK & has no excessive play in it, neither do the joints in the prop. But when I grab hold of the prop, I can turn it 1/4 of a turn either way, which results in a "clonk" at the end of each turn.
I need to get this sorted before April, when I plan to have it back on the road. HELP.
Jamieandthemagictorch
[IMG]http://upload.alfa145.com/files/8/AlfaSpider/AlfaSpiderCollageC.jpg[/IMG]
Old 01-22-2004, 06:00 AM
papajam's Avatar
papajam papajam is offline
With the propshaft having that much freeplay, I'd say that something in the diff has given up. I think about 1/4" - 1/2" freeplay is about the max. Is the pinion flange nut tight?
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 01-22-2004, 07:27 AM
Keven's Avatar
Keven Keven is offline
Are you sure your U-joints are not worn? Also is the donut ok?
I would tend to replace these items first, because they are realitvely easy and cheap, compared to tearing down the diff.
Im in the middle of a diff rebuild, and there really isnt much that can go out besides bearings. If one of the pinion brearings goes, I guess it could affect the backlash to the diff gear, and give you exess play? Other than that I cant think of anything else in there that could cause that.
1978 Spider sold in 1996
Old 01-24-2004, 08:56 AM
alberbat alberbat is offline
Member
Unhappy Prop shaft freeplay
Well at the risk of being an idiot, how do you measure slack in the prop? I guess I mean where? I'm only thinking about the diameter. My prop has a thunk in it but I'm trying to ignore it after all the other things I've been doing.
Bill
Old 01-25-2004, 07:09 PM
gotglasses gotglasses is offline
When you make a turn your differential is working - yours isn't.
Jack up car on one side and turn the rear wheel , there should be smooth resistance to turning, assuming you have a limited slip diff. If you have an open rear, no posi , the wheel should turn very smoothly. If it's rough and jumpy you differential gears are shot and you need a new rear end. The little broken gear pieces will make a mess of everything else in there. A visit to your local recycler will have it right cheap enough.
