Hi New2alfa,
I have recently rebuilt my steering box, mine had no oil in it, just a little grease. Everything looked clean and shiny and thought all I had to do was put some oil. Then I thought since I have taken every piece of my Alfa apart to clean and change seals and check for wear, I would to the same to the steering box.
Lucky I did, the bearings were all pitted and the shaft was too and not to mention some water and rust in the bottom of the box. I replaced the bearings and replaced the shaft and removed some shims to suit the new shaft. I used BP EP-90 oil. Up the top of the shaft is another bearing which had rust and plenty of it. Every spray of WD-40 released more rust, so I decided to pull it apart, the little ball bearing were OK so I filled it up with grease and reassembled it and now my steering is soft and smooth.
Neil,
I don’t understand, why it is necessary to drill a hole in the plug to vent the box? Isn’t there enough ventilation in the steering shaft going up towards the steering wheel?
I think I have answered my own question, drilling the plug hole will allow it to vent in the engine bay rather then inside the car, is that correct? Is this why you drill the plug hole?
Rich
P.S Can post you some pictures if you like?
