Old 01-29-2007, 03:35 PM
alfaboy85 alfaboy85 is offline
Engine Reinstallation
So my engine is all clean and ready to go back in but I'm faced with a dilemma: Do I mate the engine and transmission now and remove the steering rod that blocks me from putting back in as one piece or do I put the engine in and mount the trans from under the car. I would rather do it in one piece to save the hassle of the main bolts and dealing with the firewall and intake plenum blocking me, but I worry about how difficult it will be to remove those old nuts and cotter pins. Any suggestions or experiances you guys can share?
Mike
85 AF Spider Graduate
88 AF Milano Verde
Old 01-29-2007, 03:52 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
If you've got the option of putting it all in in one lump, I'd suggest going that route myself.
If the tie rod ends on the center link (and outer ends) are that bad off, it might actually be time to consider replacing them as a matter of course. (which just happens to be an easier task with the engine and trans out anyway )
Darren
as hosted by
Old 01-29-2007, 04:17 PM
well its not that they are bad its the hardware holding them in thats a little rusty. So its better to put it back in as one piece? I was gonna replace all the suspension bushings anyways so I guess I need to get to work on those in the middle. Does anyone know where to buy the replacement hardware because I've looked at my hardware store here and they dont have those special nuts and bolts?
Mike
88 AF Milano Verde
Old 01-29-2007, 05:47 PM
I doubt a hardware store will suffice for your replacement needs. Have you looked at the alfa suppliers catalogs/websites? There are many, incl some in Cal. Also, Centerline , Alfa ricambi, IAP, Vicks, DiFatta, etc.
Joe
ghnl ghnl is offline
If you want to move the center tie rod out of the way without removing the tie rod ends (thus ruining your alignment) you can unbolt the idler assembly (three bolts). That will lower the center tir rod down out of the way.
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 01-29-2007, 06:44 PM
so the three bolts youre talking about are the ones by the steering box right? Oh and I have looked through IAP and centerlines catalog and they dont have the nuts and bolts just the bushings, i'm going to call and talk to them tomorrow though then we'll see what happens
Mike
88 AF Milano Verde
Old 01-29-2007, 07:31 PM
On the opposite side from the steering box is the idler assembly. In the exploded diagram below part #1 is bolted to the body by three bolts #7.
- - Eric
don't read this
Old 01-30-2007, 05:02 PM
OK, I follow you.... I would go to a dedicated bolt/screw supplier in area, and make sure you get the heat treated (I think the term is) bolts, not the Home depot junk. they will have certain numbers stamped on top, for the grade. The guys at the bench should be up on this.
Joe
