Old 01-29-2007, 02:35 PM
CarlosSpider's Avatar
CarlosSpider CarlosSpider is offline
Brake caliper removal.
Reading the CarDisc Service Manual, in the unit 21, Front suspension, page 6 it says:
“it is possible to remove the front caliper from the steering knuckle without uncoupling it from the hydraulic control system”
How can I do it?
It´s necessary to unscrew the hydraulic pipe support on the steering lever? Then the steering lever is loosen and I don´t see how can I tighten the nut with the splash shield, disc and hub fitted that cover the screw.
Carlos
Alfa Spider Veloce 2.0
