Old 01-27-2007, 03:05 PM
alfaboy85 alfaboy85 is offline
85 Spider
Okay so this is my first post here and I need some information before I keep moving along with my 85. I have already taken the engine and trans out to do a thorough cleaning and replace the clutch. So I figured with the engine out what better time to replace the suspension bushings, springs, and shocks. Now I know I need a special tool to remove the springs, aso do you guys know where to purchase that? Do you have any tips I shoudl know or links to tips? Also I cant seem to get the dipstick back into that rubber sleeve due to a rip in the rubber, does IAP sell a replacement? Are there any other projects I should tackle while the engine is out. Mind you this car has never recieved any kind of love in this sense so everything is from the factory. Thanks!
Old 01-27-2007, 03:19 PM
Peter's Avatar
Peter Peter is offline
AlfaBB Addict
Welcome to the board. There have been several threads around spring removal.
Here's a good one with great information and pics:
Installing Front Spring (compression)
Peter
Currently:
'69 Euro 1750 GTV
Previously:
Old 01-27-2007, 03:31 PM
Okay that works but how do i take the old ones off? Also any tips on the rusted hordware around the bushings? I've been spraying them with penetrant to prep for when i tackle them but is there something more i should know?
Old 01-27-2007, 04:00 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
Same way as that thread describes AFA the threaded rod is concerned.
Just go slow and use caution and it'll be done in no time.
Rust around what bushings BTW?
Darren
as hosted by
Old 01-27-2007, 04:20 PM
Re the oil dipstick rubber connector with bracket, pull it all out, unscrew both bolts, remove rotted rubber, clean all metal with paint thinner, and dry, then get a 1/2" ID rubber black hose, at auto parts (if you ask for a sample-2", should be minimum or no charge), OD will be about what you will need, as OD's are usually relative to the ID. Put a dab of oil so dipstick tube will go in easy, and re connect. Rusted bolts....depends on how bad. Sometimes, penetrant is useless if the iron is fused .Springs, have no experience here.
Joe
Old 01-27-2007, 07:32 PM
ghnl ghnl is offline
The best penetrant I've found for rusty nuts & bolts is "P B Blaster". I've also heard that "Kroil" is good but I've not used that product.
Don't bother with WD40. It doesn't work near as well the above.
While you are cleaning things in the engine bay remove the oil vapor separator (black cannister on the right inner fender) and soak it in solvent. If/when it plugs up with crud it will prevent the sump from being able to vent crankcase pressure. That can prevent the engine from running right &/or encourage oil leaks. Also check or replaqce the small diameter oil drain hose that goes from the separator to the base of the dip stick tube.
What condition is the radiator? A good 'old-fashioned' radiator shop can pressure test it and thoroughly clean it out internally.
Finally, motor mounts sag over time and deteriorate with exposure to oil. They are difficult to replace (especially the right side) with the engine in place & all assembled. Be aware that I have read reports of new mounts that are too soft (wrong type of rubber?).
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 01-27-2007, 11:38 PM
okay, so you use the threaded rods just backwards that makes sense. I've been using pb blaster since i had a vw beetle and yes that stuff works miracles. I guess what I'm asking is what bushings should be replaced, I mean IAP has the whole list and I wanna use the polyurethane wherever I can. I replaced the motor mounts with IAP's pirelli motor mounts. As for the seperator, i never thought of that and I will most definately do that. As for the radiator, as far as i can tell its all stock and I'll probably just get it pressure tested before I reinstall. I guess I'll just keep the questions coming though: What experiance do you have in increasing the rear sway bar diameter? I've been looking into after market rims but alfa's 4x108 pattern makes it difficult to find rims, any suggestions or links to threads that explain my options? I've been lookin into lug pattern converters but the thought of making the wheels look wider has me second guessing. And i'm not completely fakilar with the acronyms buts whats ID and OD?
Old 01-28-2007, 07:16 AM
There is some controversy about poly bushings in the rear trailing arms. Someting about them being too stiff and actually making the handling worse. Try a search for opionions about that.
Before you spend too much on upgrading springs and sway bars, consider a 'chassis stiffener'. Those that have 'em say it made a big difference in handling.
- - Eric
don't read this
Old 01-28-2007, 09:23 AM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
Posted by alfaboy85
...I guess what I'm asking is what bushings should be replaced, I mean IAP has the whole list and I wanna use the polyurethane wherever I can...
My '84 Spider has polyurethane everywhere, including the motor mounts. I ordered most of them from Centerline, and also from Performatek. Ereminas Imports is the only outfit that has developed poly motor mounts for the Spiders. IMHO poly is the way to go.
You are right about it being a good time to upgrade the suspension components. The OEM springs are very soft, and any street performance upgrade (from IAP, Centerline, Ward & Deane, or the European sites) will give you a much better ride, without sacrficing any comfort. Nonetheless, do a search for threads covering those topics, as there have been some wonderful discussions, and ultimately it is a matter of personal preference. Below are 3 threads that you may find interesting. (Do read them through, as we are not infallible on this forum, and you will notice how we clarify misconceptions as discussions proceed.)Another point to keep in mind regarding suspenisons is that the better known upgrades have been based on R&D performed in the '70s, and there hadn't been any new developments for several decades. However, do note that recently a modern suspension (coilovers) has been developed by RSR Racing. Personally, if I was upgrading a Spider suspension, I would give this set-up serious consideration. Here is one thread about these components: New RSRacing Suspensions In At G2 (also 105!). Iin the last few weeks, there were several tech sessions held around the country, where some of us got to see these products first hand.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 01-28-2007, 03:09 PM
So the whoel setup through RSR is 1200 pounds, my pound to dollar conversion is a little rusty, but that absolutely obliterates my budget because when i laid all the parts out form iap the bushings, springs, shocks, and larger rear sway bar would cost around $1300. I guess what i'm looking for in suspension is a sporty feel but track use doesn't matter because where i live theres no real option to use the car in a track setting(besides laguna seca but yeah right i'm gonna get on there). Is this just something I should call and tell the people at IAP or centerline and get an opinion from them, or are they just gonna push their product?
Old 01-28-2007, 04:42 PM
Zunige's Avatar
Posted by alfaboy85
...or are they just gonna push their product?
Of course they are going to push thier product... All sellers also believe that they have a good set-up - and both Centerline and IAP do have a good set-up. For a traditional approach (non-RSR), with a sporty feel those are good choices. Do read the threads and you will find opinions on both Centerline and IAP. (I happen to have the Centerline springs in my '87 Spider, and have been very pleased with them. The others have Ward and Deane, and Shankle, but that doesn't mean that the IAP's set-up isn't a good choice.) Since you are looking at alternatives, after reading the threads, I would compare each suppliers set-up, including prices, and follow-up with a phone call to each. It is advisable to go with a full set-up from one supplier and not mix and match. You do want a suspension that achieves balance between the front and rear, and appropriate shocks for your ride preference.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 01-29-2007, 12:42 AM
lol i guess that is true good point, yeah i read the links you gave me and it did give me insight so I'll be calling centerline and IAP tomorrow. Thanks for all the help guys, this forum is invaluable especially for the alfa newbies like me
Old 01-29-2007, 11:33 AM
gdpedersen's Avatar
gdpedersen gdpedersen is offline
Posted by alfaboy85
I would replace the motor and transmission mounts
85 Alfa Graduate
