My thoughts
Eh... What's up Doc,
Okay, that is my small attempt at humor,
NOW to the real business, Your Alfa.... I would first get out a wiring diagram, and see what is interconnected and where. If you dont have a diagram, there are many listed here on the BB, and through aftermarket dealers.
That being said, It sounds to me like you have a bad connection along the lines, where something is corroded, and metal is touching wire causing a short.
If its both your windows, and your heater, then I would first take apart what is easiest AFTER YOU CHECK THE WIRING CHART... The doors being the easiest to disassemble.
Even if wires look "OKAY" take them apart any way, and clean the contacts, then seal them with a water repellant/electrical spray.
Usually with things like this its something really stupid causing the problems, so take your time, dont get frustrated, and learn to curse in Italian, LOL ..... IN my experience my alfa's respond best to foul language HA HA HA HA HA....
Best of Luck....
AR 1750.
