Now moving on the Programmable FI system:
I knew with the changes I was doing that the existing Motronic ecu was not going to handle it and I started to look at piggy back systems, I found out that the one thing a piggy back system can’t do is change the factory programmed rev limiter which is set at 6,200 rpm’s and my engine was going to have a red lne of 8,000 rpm and a shift point of 7,500 rpm, this forced me into the stand alone systems. When the Dual VVT’s were added this narrowed it down to just a few to choose from in which I selected the Autronic’s SM2.
Here’s a short overview of the system: (I have the 1.92 version)
Features:
• Sequential operation for 2 to 8 cylinder engines.
• Eight injector outputs.
• Four ignition outputs (ignition expander available for up to 8 outputs)
• 3D fuel and Ignition maps.
• User defined up to 32 RPM and 16 Load sites = 512 sites.
• Eight auxiliary outputs other than fuel pump control.
• Auxiliary outputs can be defined for boost control, nitrous oxide, staged
• injectors, camshaft timing, AC, fan control, idle valve etc...
• Traction Control
• Flat Shift. (ver 1.92 & 1.93)
• Launch Control. (ver 1.93)
• Anti-Lag
• Data Logging
• Available with high current drivers if required
• AutoTune option available
• Compatible with Motec Dash
Here's the link:
Autronic Fuel Injection Accessories
