Old 08-15-2006, 04:28 PM
fetta78's Avatar
fetta78 fetta78 is offline
Who Makes That?
Car Starts, Runs For 2-3 Seconds...Dies!
1986 Spider. Starts right up, runs for two or three seconds then dies.
I've replaced the in-tank pump, main pump, both relays near computer as well as the computer itself with known good ones off a running car. All grounds checked, at least a half tank of gas.............
I put a power test light on the in-tank pump connection, it lights up for a flash when the key is on then nice and bright untill the car dies when the light goes out. Same with the main pump, running like a champ till car dies.
Any ideas?
1986 Spider
1992 164 S
Old 08-15-2006, 04:51 PM
ghnl ghnl is offline
Check for air leaks in the intake system. Loose or cracked hoses. The 'accordian' section of the plastic intake duct is known to develop cracks.
Is the harness connected to the air flow meter (on top of the air filter)?
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 08-15-2006, 05:10 PM
fetta78's Avatar
Who Makes That?
No air leaks, all intake tubes like new and checked, main harness on AFM checked, even tried un-plugging the aux air valve just to see if that would help any......no change!
1986 Spider
1992 164 S
Old 08-15-2006, 05:49 PM
Have you checked the flywheel sensors? (although I don't think it'd even run for a few seconds if they were to fail...)
- - Eric
don't read this
Old 08-15-2006, 07:54 PM
Toptick's Avatar
Toptick Toptick is offline
Send a message via AIM to Toptick
You also might check the fuel lines between the pump & the engine. If you have a crimp/clog you might get the same symptoms as a bad pump--Lack of fuel pressure.
Art Graham
'86 White Spider Graduate
'83 White (& Orange) Jeep CJ-7
'84 White Honda Spree (Summer Village Transport)
'99 Black BMW 323i--Kids can't touch it.
'03 Blue BMW 325XIT--Mine!
'03 Volvo X/C 70 (SWMBO)
Too Many Cars in the Driveway!!
Old 08-15-2006, 09:20 PM
jmshyla jmshyla is offline
Check Greg Gordon's L-Jet Tuning Website
I seem to recall that the "starts then stalls" syndrome can be caused by a stuck AAV.
http://www.hiperformancestore.com/L-jetronic.htm
Old 08-22-2006, 02:57 PM
fetta78's Avatar
Who Makes That?
Okay.....took the day off work to try and get the Spider running so I can
take it to the Keeneland Concours in Lexington KY this Saturday but........
Still no change!
To re-cap, Blew fuse for fuel pump located behind passenger seat near
computer. Replaced in-tank fuel pump and fixed the terminal that was
causing the short. No more fuse blowing! Yay!
Now car will start right up and run for two or three seconds before dieing.
I have checked and rechecked fuses under the dash. I have replaced both
computers from a running car my father in law has let me use. I have
replaced the two relays behind the passenger seat. I have removed the AFM
and hoses and checked to see if the air flap was stuck and looked at the
hoses, all good. I replaced the black box thingy mounted on the intake
manifold, I checked the fuse in the red cylinder thing under the hood by the
coil. I unplugged the Air Aux Valve....
I have a fuel pressure guage on the way just to rule out that but there is plenty
of pressure at the rail when I loosen the hose!!
This is getting crazy! The car starts right up, runs great then dies.
Something is not switching over and I can't figure out what that
something could be!
Any other ideas? Please?
1986 Spider
1992 164 S
Old 08-22-2006, 03:03 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
AFM wiring inside it's harness plug clean, tight, and connected? (reaching)
Darren
as hosted by
Old 08-22-2006, 03:05 PM
fetta78's Avatar
Who Makes That?
Yes sir! Even used contact cleaner when I replugged it in!
Keep tryin' folks......I gotta get it to Lexington Saturday and NOT on a trailer!!
1986 Spider
1992 164 S
Old 08-22-2006, 03:26 PM
It sounds to me like the main injectors are not firing. To verify this have a buddy spray starter fluid into the intake as you crank it. If it will keep running as long as starter fluid is being sprayed then the main injectors are not firing.
Assuming they don't fire the next step is to figure out if they are clogged, stuck, or not getting a signal. All three things require different solutions. If it was a V6 car I would bet it's a signal problem, however with the 4cyl only 2 need to be bad to prevent it from running so they could be stuck or clogged.
Old 08-22-2006, 03:53 PM
I replied to the Alfa Email Digest with what could be a crazy idea. Does your Alfa have an inertia shut-off switch? If it was flukey might it allow the car to fire then kill the fuel pump? I believe the inertia switch can be bypassed by connecting its two wires together.
- - Eric
don't read this
Old 08-24-2006, 03:17 PM
socal-85 socal-85 is offline
This is an older post, and I hope you had the problem resolved by now...
I just wanted to ad my 2cents...
I've had the exact same problem with my 85 Veloce.
just about every major electrical component was replaced including the flywheel sensors... it would start right up then die...(as if the cold start valve was giving it just enough gas to fire, then sputter out.
I checked all the fuses in the red screw together holders and they were fine.
the car sat for the better part of a month while I was waiting for my F/W sensor to show up (back order) I installed it and nothing....... I noticed that if I unplugged all the fuses it would still start and die right out?
then I saw it...... there are 2 10mm bolts holding the AAV to the top of the motor. they are also the grounding points for 2 sets of wires... I was missing a bolt.... I put the 2 sets together, tightend, and I was up and running.... no problems since.
hope this might help somebody, somewhere.
Old 01-08-2008, 01:07 AM
danyl's Avatar
danyl danyl is offline
Better late than never
You may have just helped me! It's a YEAR later than your post, but I recently moved one of my grounding wires to the other side of the AAV...about the same time my start/then/die problems arose. I'll change them back and see what happens....
  #14 (permalink)
Old 01-08-2008, 06:32 AM
fetta78's Avatar
Who Makes That?
If I remember correctly it was a flywheel sensor that finally fixed the problem on that Spider!
I think..............
1986 Spider
1992 164 S
  #15 (permalink)
Old 01-08-2008, 11:02 AM
rictorg's Avatar
rictorg rictorg is offline
Send a message via ICQ to rictorg
It'll turn over, but won't start. (experience) =)
1983 Spider Veloce
