Old 07-08-2006, 01:31 PM
greg's Avatar
greg greg is offline
1969 Roundtail Numero Uno
Burman steering box in roundtail
Hi is anybody can tell how burman box attached to body shell.
My old box is cracked I got used one, but when I took out old one it was attached straight to body is it correct ??? I think this why it cracked.How it need to be attached?
1969 1750 boat serial 105.62.14800001 Numero UNO
ex 1992 spider can't afford 2
ex 1986 alfa33s
Old 07-09-2006, 05:42 AM
ossodiseppia's Avatar
pffffffffffffffffffffff!!
Where was it cracked? The box typically cracks along the bolt holes that hold the steering shaft. I believe there was a fix that envolves using spacers where the box mounts to the car and where the shaft mounts under the dash. Papajam posted the repair, so do a little search and see if you can come up with it.
Old 07-09-2006, 07:33 AM
greg's Avatar
Thank you what kind of spacers these are.Mine was was cracked on top beside the 4 bolts towards the rear.
Thx
ex 1986 alfa33s
Old 07-09-2006, 11:08 AM
60sRacer 60sRacer is offline
Gee, Osso
MORE of your incredible collection of photos!!!!
Just marvelous!!
Robert
Old 07-09-2006, 11:37 PM
larry larry is offline
Often there is a triangle shaped alum. one piece spacer, just like the one under the Idler, Mirror images, they are not the same thickness at all three points. I have also seen the individual spacers, different on all the models and years. The frame rails are not parallel, X or Y axis. I will rty to take pictures of some at the shop tommorrow.
Larry
Alfa Parts Exchange.
Larry
Old 07-10-2006, 04:43 AM
greg's Avatar
Hi Larry I'm the one ( with strange name) that bought from you the box do you have the spacer ?
ex 1986 alfa33s
Old 07-10-2006, 07:33 PM
papajam's Avatar
papajam papajam is offline
Thought this little tidbit would help with the steering box installation.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 07-10-2006, 07:41 PM
greg's Avatar
What is the right size for types of washers
Thx
ex 1986 alfa33s
Old 07-10-2006, 07:46 PM
PSk PSk is offline
Thx
If you mean thickness you will need to trial mount your steering box per Papajam's instructions and measure and then make (buy) some of the right thickness.
Old 07-10-2006, 07:49 PM
papajam's Avatar
I have a set I can measure for you tomorrow.
Old 07-10-2006, 08:01 PM
Ok, these washers are used on a couple of different places on the car. So, maybe you can scavenge some off a parts car.
2140.16530-Is the same washer that goes between the bolt that holds the lower control arm mount and the body.
2140.16677-Is the same washer that goes on the nut that secures the lower part of the front shock to the lower A arm.
Both show as being 10.5mm washers, but I am sure they are a different thickness'.
Old 07-10-2006, 08:10 PM
Those are two fairly standard metric washers. Should be easy to find at most parts stores. No special hardness, or thickness. Pretty standard steel washers.
Robert
Old 07-11-2006, 05:28 AM
Robert
I don't think they are. If you get the wrong thickness of washers, that could throw the shaft or column out of alignment and he'd be back where he started. The one that the box mounts too is quite thick compared to the fender wahser that is used on the column. Sorry, I don't have a micrometer to measure them.
  #14 (permalink)
Old 07-11-2006, 03:27 PM
papajam's Avatar
Measured six washers today; three from the steering box mount and three from the idler arm. They are all the same size;
OD=22mm
ID=10.5mm
Thickness=2.6mm
Material appears to be hardened (like grade 10.9) steel.
Sorry, don't currently have easy access to any column washers.
  #15 (permalink)
Old 07-11-2006, 03:31 PM
greg's Avatar
Papajam, is OD means overall diameter ID inside hole.
ex 1986 alfa33s
Threaded Mode
