Old 11-08-2003, 11:50 AM
lawrencedesigns's Avatar
lawrencedesigns lawrencedesigns is offline
Fuel tank pressure
Now that I have this 84 spyder on the road, I am noticing every time I open the fuel filler there is a rather substantial "whooosh" of pressure release.
I don't remember this happening years ago on my 74....
Any thoughts?
Keeth Lawrence
84 spyder
Old 11-08-2003, 02:13 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
Sounds like the vent system is clogged.
John Stewart
74 Spider
Old 11-10-2003, 07:59 AM
Keven's Avatar
Keven Keven is offline
Yes, clogged tank vent system, clear it immediatley, cause it is straining your fuel pump. THe pressure can get so bad that the pump will start blowing fuses.
Do a search, someone else fixed this problem recently, and I recall a faulty one way valve somewhere in the system.
1978 Spider sold in 1996
Old 11-10-2003, 08:31 AM
Roadtrip's Avatar
74 Alfa Spider
I'm not positive on the 84s, but there's probably the vapor recovery tank inside the trunk with some small tubes coming out of it. On one of the tubes theres a small dead-ended looking valve. That valve allows air in (as fuel is used). If it's clogged up you can get negative pressure in the tank and cause fuel starvation and supply pump damage. In very damp freezing weather, it can freeze up.
John Stewart
74 Spider
Old 11-18-2003, 09:40 PM
Gubi's Avatar
Gubi Gubi is offline
I'm having the exact same problem right now with positive fuel tank pressure on my '91. On the vent system, the separator and both check valves in the trunk are fine. On the other end, the solenoid into the plenum is functional if I put a battery onto it.
So either the solenoid isn't getting power or the carbon cannister is clogged up. Two questions:
1) Under what circumstances should the computer open up the vent system solenoid into the plenum? I'm assuming it opens when the engine is warmed up at higher RPM's..correct? I want to check it with a multimeter and see if it's getting voltage.
2) Anyone ever had a carbon cannister get plugged up? Seems like an odd thing to happen, but I suppose it's possible.
Thanks!
Old 11-19-2003, 01:29 PM
Coqalfa Coqalfa is offline
Cool
Another possibility is the residual pressure developed by the "in-tank pump that precedes the filter. In the Bosch fuel injection systems, they require some residual start-up pressure in the system. This may be the source of your "whooooosh"!!
Regards, Brian
PS: Bosch does have a procedure for draining that pressure prior to replacing the filter.
87, 71 &60 spider owner
Old 11-19-2003, 03:16 PM
Gubi's Avatar
Regards, Brian
Well, that would be pressure in the fuel lines, correct? What I'm seeing is vapor pressure in the tank.
Went over to a buddy's place today to use his air compressor. Looks like the solenoid is working correctly. However, I can't get any flow from the check valve in the rear to the solenoid in the engine bay...seems blocked up. Looking more and more like the carbon cannister is the problem for me.
Figured as much, as it's the least accessible component of the whole vapor recovery system
