Old 07-03-2006, 07:17 PM
E.J.'s Avatar
battery terminal connections
The bolts on mine are ground into the terminal and they don't tighten around the battery so well anymore. Considering.
1. Washers so bolts don't grind in.
2. Replacing connectors
3. Replacing the whole battery wire (would rather not do this as im sure its going to be a real pain.
Anyone have this similar problem? What did you use as a solution?
[FONT="Garamond"][SIZE="2"][COLOR="Blue"]86 Alfa Graduate
86 Ferrari Testarosa
89 Maserati Bi Turbo Spyder
00 Range Rover Land Rover[/COLOR][/SIZE][/FONT]
Old 07-03-2006, 07:29 PM
Tifosi's Avatar
Darth Slacker
Option #2 on the postive*
Option #3 on the negative (it's only about 12-16" long in total and bolts into the chassis right there behind the battery)
*to do the positive cable in it's entirety you need to find a length of wire literally as long as the car as it goes from battery, down under the chassis, chases a 'frame rail' next to the fuel lines until it terminates at the starter.
Far more efficient to check the exisiting ones condition then get a solder on (not clamp on with bolts) type end to put on it.
Darren
as hosted by
Greg Gordon's HI Performance Store
Old 07-03-2006, 07:38 PM
Farace's Avatar
La Dolce Veloce
I'm planning on replacing my cables with ones that have tinned bronze clamps. No more digging into the lousy lead connector. I don't know that I'll go with this company, but this is the sort of thing I want:
www.custombatterycables.com
Heavier gauge wire, too.
Bob Farace
1987 Alfa Romeo Milano Gold
Director, Connecticut branch, Scuderia Non Originale
Old 07-03-2006, 07:51 PM
artart's Avatar
Shave a bit of the connector portion of the terminal
My bolts and terminals were doing a similar thing, the two end tabs of the terminal were touching from being tightened. I removed the bolt and wedged a file between the ends and shaved off a bit of each so the insides no longer come completely together when the bolt is tightened.
I agree that the negative is easy to replace and the positive would be a royal pain and very expensive. If you do replace the negative, make sure you get a heavy gauge, not the thin ones that i've seen in some stores.
Artart
1988 Graduate-it goes!!! :-)
1987 Graduate- always wanted twins
1990 Sears 10hp Rider- it mows ;-)
1996 Isuzu Rodeo-for taking my canoe to row
2007- Nissan Quest- room to dose )
1965 Lambretta- go no more:-(
Old 07-04-2006, 09:01 AM
kennypinkerton's Avatar
If you find you need to replace the positive cable, the least expensive cable you can buy would be found at a welding shop. You can get very large guage cable there in any length for less than half of what most places will charge you for normal automotive battery terminal cable.
Kenny Pinkerton III
1984 Spider Veloce
1977 MGB
1995 Toyota 4runner
1963 Snipe Sailboat
Old 07-04-2006, 12:04 PM
I replaced my positive end with the Heavy Duty clamp from NAPA. The heavy clamp is designed for large trucks so is much beefier than your standard replacement end. You will have to turn the clamping strap upside down so you get a good connection on car sized cables.
Dave
Old 07-04-2006, 12:54 PM
Farace's Avatar
La Dolce Veloce
Keep in mind that those bolt-on replacement clamps are meant to be temporary only.
Bob Farace
Old 07-04-2006, 03:57 PM
Huh
Old 07-04-2006, 06:00 PM
Farace's Avatar
La Dolce Veloce
Originally Posted by pribis
Huh
They were never meant to be anything more than a temporary fix. They build up corrosion constantly where the bare wires are clamped between the metal strap and lead body (every year I scrap crud off my "temporary" cable end). They're also a compromise size, which is why they don't fit quite right on the battery--they're too tight on the positive terminal, and too loose on the negative. I wish I could remember where I read everything I read about them, but if you do a search on the net, you'll probably find a lot of good reasons not to use them for very long.
Bob Farace
Old 07-05-2006, 05:57 AM
Rich's Avatar
Gold Battery Terminals
Hey EJ,
How about these, the one with the display will give you the voltage of the battery while the engine is on and when you turn the engine off the display stays On for about a minute.
Rich
Old 09-29-2009, 04:23 AM
Rich's Avatar
Just going through my cabling to redo a new harness, and I found a few battery cables and all have different connectors for the positive side. The one I like and I guess looks original it is made of lead with the cable cooked/baked into the connector with one 4mm red wire, am i correct in saying this is the original? Can you still buy one of them? If not, I'm going to try to file mine to so that it looks better otherwise I try to make one. Has anyone tried to make one of these lead terminals?
After searching battery terminal, I came across this thread, which i killed with my ugly suggestion in the above post, sorry.
I don't think i want to go with something that modern and shiny.
Rich
Can some post a picture, please.
1974 Spider 2.0L
Old 09-29-2009, 10:40 AM
vf31rhill's Avatar
Rich,
Where does one get these gold terminal ends? I replaced my ground wire with heavy duty new, but my + end is getting stretched and I do not want to remove and replace 15ft of battery terminal wire.
Thanks, Robert
1988 Black Spider Veloce
Old 09-29-2009, 12:56 PM
Tifosi's Avatar
Darth Slacker
Working lead is easy, and likely you could use the metal from your existing terminal, + mabe a lead sinker to make up for material loss to make a new terminal.
You'd need a propane or MAPP gas torch, and something to melt it in that you can pour from. (a small disposable steel saucepan would work)
The mold is the hardest part as it has to (1) be accurate, (2) sustain the heat of the molten lead, and (3) be easily removable from the finished product.
#2 and #3 are the hard part of the whole process, especially given that the mold would also have to allow for the cable end to be present in there too so it can all merge together into one sexy unit.
Unless you're going for concours, I'd suggest one of the soft steel or copper terminals that has the provision to solder the end of the cable in rather than any sort of pinching, wing nutting, or clamping affair. (and if you are going concours, I'd do the solder on anyway, because judging on battery terminal correctness is really kinda anal in the grander scheme of things. Like a factory mech or authorized dealership repair shop would strip out a whole cable just to fix/change/replace the end. Riiiiiight.......)
With that type you simply melt off the old lead terminal (put a cookie sheet under things to catch the drips-n-spatter), clean and tin the end of the cable like you would any soldered electrical connection, then stuff it into the terminal receptical, heat and flood with more solder yet.
When it cools, clean off any excess solder and flux residue with a wire toothbrush and mabe give it a spritz of clear or colored spraypaint to seal against oxidation, or dope it with liquid electric tape or contact grease (again to seal against oxidation) and shrink wrap the cable to terminal joint (don't forget to put the shrink wrap on the cable BEFORE fitting ther terminal, and slide it way back there---> on the thing so it doesn't shrink before you actually get to use it LOL) then hook it up and forget about it for somewhere around forever.
Darren
as hosted by
  #14 (permalink)
Old 09-29-2009, 02:34 PM
aldo's Avatar
FORZA ASSERGI
Originally Posted by vf31rhill View Post
Rich,
Thanks, Robert
Try here: GOLD-PLATED BATTERY TERMINAL AND POSTS - JCWhitney
Ciao tutti
93 Spider (red)
87 Milano (not red)
  #15 (permalink)
Old 09-29-2009, 03:31 PM
vf31rhill's Avatar
It is also dangrous if you breath the fumes coming off the moltent lead. Lead will give you heavy metal poisioning and breathing the fumes is the easiest way to get contaminated. The good part is that your body will eventually rid itself of most of these toxins if you end your exposure. Nothing wrong with doing your own lead forming, but just be careful of exposure to the fumes.
Robert
