Old 05-08-2006, 09:51 PM
lunchbox lunchbox is offline
Send a message via AIM to lunchbox
Tachometer cable
How do i remove the tachometer cable from my 73 2000 spider? It seems like i could get a screwdriver and start it since it's grooved.... but to get in there is pretty tough... did italians have really tiny hands???
Sam
Old 05-08-2006, 10:20 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
Remove the black "eyebrow" bezel around the tach. To do that, remove the screw at the bottom and rotate the eyebrow up. Then remove the two screws that hold the tach in the black pod. Pull out the tach slightly and disconnect the cable. 2 minutes.
John Stewart
74 Spider
Old 05-08-2006, 10:25 PM
ya.... got that..
Ya, i got that part, that was pretty basic. I'm talking about where the Cable connects to the engine block. It sits right behind the alternator and its a tight spot. I would like to know if it's necessary to take some parts out first. Thanks.
Sam
Old 05-09-2006, 12:15 AM
O ya, and when i connect this new tach cable, should i grease both ends?
Old 05-09-2006, 05:33 AM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
Preferably you would pull the cable from the sleeve, lube the section that would normally be in the sleeve but avoid getting too much, if any, lube on the ends. (a tach full of cable lube is a bad thing)
Darren
as hosted by
Old 05-09-2006, 08:28 AM
Roadtrip's Avatar
74 Alfa Spider
Oh, yea. The other end. Well, that's a different story. It's pretty tough since the lockring is probably corroded onto the threads. All I can suggest is some channel locks, or as you suggest, a screwdriver and light hammer. If it's really on there, you'll probably have to damage the cable in the removal process and replace it.
John Stewart
74 Spider
