rear end noise - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 03-11-2013, 08:47 PM Thread Starter
rear end noise
Took the 74 spider out of the winter garage. I notice what seems to be a slight vibration/ noise from what I think is the right rear side at road speed with a turn to the right. A turn back to the left, even a lane change ,makes it go away. Rear wheel bearing? Anything else? Thanks. Ken.
alfadad is offline
post #2 of 6 (permalink) Old 03-12-2013, 03:42 AM
Send a message via Skype™ to 89veloce
You might check for a brake dragging. Not sure what you had on 74s.
89veloce is offline
post #3 of 6 (permalink) Old 03-12-2013, 07:01 AM
same issue
Mine was a wheel bearing. I put some extra grease on it and the noise was greatly reduced. I then replaced it and had no further noise.
richwr is offline
post #4 of 6 (permalink) Old 03-12-2013, 11:27 AM Thread Starter
Thanks for the advice. The book makes the rear wheel bearings a chore to deal with though.
alfadad is offline
post #5 of 6 (permalink) Old 03-12-2013, 11:33 AM
replacing wheel bearing
I followed this thread to replace mine.
Rear wheel bearing replacement
richwr is offline
post #6 of 6 (permalink) Old 03-13-2013, 09:19 AM
gigem75's Avatar
The rear bearings are sealed so the grease that fixed your problem had to of fixed something else. I'd almost prefer any other task up to r & r engine/trans over replacing a rear wheel bearing.
currently
74 GTV restored daily driver
71 Berlina in resto
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
gigem75 is offline
