07-18-2012, 01:35 PM
Originally Posted by Stevew
If I may be so bold, what was your cost of liberating this beauty from the barn.
Also, looked over your list and congratulations on saving the radiator cap  !
Be sure to check that drain lines from the front cowl are clear. A transparent issue till the problems with "creeping lightness" begin. Others can tell you about additional drains that should be checked (around the back of the convertible top tray, perhaps?).
Cables for the trunk and hood release can be failing. The trunk cable rear attachment lurks out of sight under the carpet in (wait for it) the trunk! Mine was ready to go when someone mentioned it on the BB. Failure of the hood release cable can have you looking for your Sawzall. Backup arrangements on both are a wise option.
Regarding the brake MC, tell us about the pedal travel.
Believe there is also a suggested "heavy up" of a cable from the alternator that improves system voltage. You'll need to search for that one...helped my charging system quite a bit. Oh, and a variety of ground points get tired, with unpleasant consequences.
The oil vapor separator is notorious for clogging with one of the first symptoms being a dip stick that keeps mysteriously popping up.
And of course you have a pan guard, right?
How many mile on her?
I trust my suggestions will stir the memory juices of others.
Best wishes.
Thank you for the input. Cowl drains are clear. However going through this area, after her first rain, I realize I need to reseal the windscreen. I found a wet passenger floor after her first rain strm in 20 plus years.
She only had 8k miles, and sat all of her life in an enclosed garage. . Most of the miles went on in first five years, and little to none from there. I have put more than five hundred in the past week. More than I know she has seen since about 1990. She seems happy to be out in the sun again. The car was passed down, not purchased.
Brake travel seems even and normal. I've restored several vintage Porsche, and the feel is about right. I still will rebuild as a safety item.
Items added to the list:
Replace O2 sensor (running rich, and voltage is nearly none existent)
Weld heat shield on down pipe
Reseal windscreen
Lube speedo cable ( jumpy)
07-22-2012, 01:39 PM
Sounds like you've hit most everything that you can do preventitively. Now just fix things as they break.... Looks great and congrats.
(I have been working on a barn find Duetto for the past 3 years and it's great fun.)
etip
1969 Spider
07-26-2012, 04:18 PM
18 years in a barn
my 71 was a barn find. 18 years in a garage. 18 years of dust. A non Alfa mechanic gave up on her. I gave her 4 years
Reason: add photos
07-26-2012, 04:37 PM
Member
Wow 18 years. How much work (you said 4 years) to bring it current condition? Body, motor, interior paint? The car looks beautiful...that's a cool color.
Jeff
84 Spider Veloce, 84 Jeep CJ8, 73 Yamaha RD350
07-26-2012, 04:54 PM
She looks beautiful. Good to know there are more people you just can't let an Alfa waste away in a garage/barn somewhere. I swear mine is really smiling as she drives out in the sun.
There are five other non-running Spiders in my area, all looking for a home. Very attempted to make room in the garage for another one. There is a nice '87 which.............
07-26-2012, 06:13 PM
Beautiful! What a great save.
07-28-2012, 11:15 AM
I paid $2500 for her. She was complete. The interior was in pieces but all there. Almost nothing worked. I think I replaced all the items listed at the beginning of this post and more but fortunately the engine hasn't been cracked. Perfect compression. Once adjusted the Spica has been strong and steady. The timing on the Spica was 180' out and is the reason she would not run. I believe the rear wheel bearings and the motor mounts were the hardest thing but working on a car is sort of like being in pain. When you are in it you can't recall what it is like not to be in pain and when it is over our minds help us forget the horror. There was zero rust but the RR qtr panel was stoved in and there where many many smaller dent including the bump in the hood, visable in the photo, from the oil cap. Thus the paint job. Matched the original color from the underside of the cowling. `
07-28-2012, 01:54 PM
Member
Nice work, can you post a few more pics?
Jeff
07-29-2012, 07:12 AM
Born Again Boarder
If a SPica, the SPica oil filter.
Many clean and recoat the fuel tank.
Replace all soft fuel lines.
Clean OVS if one.
Chances are very high that all hydraulic appliacances are bad including boosters.
Front brake hoses.
Check/replace thermostat.
Main fuel filter.
Now - Spider Veloce, US '69 1750/4.56 LSD ( pictures)( and more) - since '75 for that early mid-life crisis!
Pinyo - '72 Giulia Super 1.6 to 2L/4.30 LSD ( pictures)( and more) - for that late mid-life crisis!!
Gina Lolo Bianca - '65 early Series 1 Super, Biancospino/lt. blue, straight stock 1600/4.56 (pics)(more pics) - just for the heck of it now!!!
Colonel Mustard - '67 Giulia Sprint GTV,Giallo Ocra/black, very stock, 1600 ( pics) - for sale - LINK
Gone - Benjamin - 76 "Nuovo" to 1600 Super ( pics) - for the 2011 Euro trip
'69 1750 Berlina (wish I still had)
Links
Pinyo's 2010, 10 wk, 8000 mi "Super" Euro-Trip Blog - LINK
Benjamin's 2011, 7 week, 3500 mile "Super2" Euro-Trip Blog - LINK
Gina Lolo's 2011 Alfa Convention, 3350 mile Roadtrip blog - LINK
07-29-2012, 08:26 AM
Junior Member
I have also been resirrecting A 1981 Spider which sat for ten years, I also had a mouse living/crapping in the trunk! Looking at your list looks a lot like what I have been going through. The one item i didn't see on your list and you might want to check is the gas tank. Mine had crap, looked like rust flakes, in the tank and the pump wires were gone? so was the tank pump filter? I removed the tank had it cleaned at a radiator shop (also had them test the radiator). I also feel the need to go through everything I can and make sure it's at it's best. I'm also documenting every step with photos so if there is anything I can do to help let me know. I have my Spica pump being rebuilt and the head is getting a valve job. Once i get them back I will be assembling it and get it running.
Enjoy your journey and good luck.
Dave
81 Spider (restore Spica) Black
81 Honda CX500 Turbo
07-29-2012, 09:12 AM
Ditto on the gas tank. JC Whitney makes a kit if you want to DYI but for about $200 you can have it done. Most motorcycle shops also sell a kit. I have seen threads on the procedure but if you can't find them PM me.
08-12-2012, 01:22 PM
Okay, two more things knocked off my list this weekend.
1. Welded the heatshield on the Downpipe. It was so bad at ~3200rpm, I thought it was the timing chain. I kept rechecking the chain but it was always just right. The sound was very "chain like''. Now that it is welded, all quiet again.
2. Replace non-functional Oxygen Sensor. Despite the low miles, it just gave no meaningful output. It was runing very rich. Now, it is purring and happy again.
Next task for the next weekend. Resealing the windshield.
08-12-2012, 07:39 PM
Replace all the rubber flex brake lines....30 yr old rubber
Murray[RIGHT][B]Darkside Member[/B][/RIGHT]
1991 Black Spider
[url=http://www.alfabb.com/bb/forums/spider-1966-up/29640-msierts-black-spider-project.html]The "Black Spider" project[/url]
[url=http://www.youtube.com/watch?v=oCkdF15xu5E][color=blue]Street Video[/color][/url]
[url=http://www.youtube.com/watch?v=8yPhJC8zlqM][color=red]Track Video[/color][/url]
08-12-2012, 08:39 PM
after you do all the work to get her on the street....................................drive the snot out of it..   i will run better....i do that once a week...
..i live on the real world,, don't belive in conspiracys
08-12-2012, 08:54 PM
Done on the first weekend.
