06-15-2012, 03:08 PM
Alternator Field Wire; 1986 Spider
1986 AR Graduate Spider 1966cc w/5 speed manual trans w/Bosch L-Jetronic Fuel Injections system. This makes it an "S3" American, I think. It has 175,000 miles recorded thereabouts.
I am mentoring the young (21 yo) owner of this vehicle which has multiple issues. The alternator was not putting out and draining the battery. 11.5 V at the battery and at the fender well relay post to which the alternator output (red) and field wire (green) are attached for relay to the system.
We removed the alternator and had it bench tested at a local shop; it put out 14V @ 60A (rated at 14V @ 55A) and held a steady 14V with no load so the alternator itself is OK.
Belatedly, we checked the green field wire voltage supply and found that it had no voltage. We then traced the field wire back to the instrument panel and identified the other end with a multimeter. The field wire is continuous (and reads 10 ohms to engine ground). We found battery voltage at the pink wire on the same connector as the field wire at the instrument panel (top middle white connector, I think, with about 10 wires in the harness. The green wire path on the circuit board is also directly connected to the voltage indicator instrument light on the board so this seems correct.
The problem is that when the ignition key is turned to the "ON" (run) position the green wire is NOT energized which it seems that it should be to energize the alternator and to activate the voltage indicator on the dash.
The 10 ohms to ground resistance of the green field wire seems correct; am I correct that it should be at ground or thereabouts?. We checked the fuse box and all fuses are continuous and the box is energized with battery voltage.
Now for the "devil in the details" part. Some previous owner had evidently had problems with his steering column mounted headlight switch and so he opened up a packet of wires and spliced a toggle switch into a battery voltage feed (red) and then connected the other end of the toggle switch to the column mounted headlight switch (yellow). This produced headlights at one time and is not working now for some random reason.
I should also mention that the top of the instrument cluster was heavily corroded with iron oxide indicating that it was exposed to rain water or something. We carefully cleaned nuts, bolts, circuit board copper etched paths around the circular "mosquito lamps" (wiping lightly with white vinegar) and the contacts on the lamps themselves. We checked continuity of the lamps etc. It was a 75 minute project with two people. The end result was satisfactory in my opinion. We also attempted to clean the wiring harness connectors by connecting and reconnecting the harness to the instrument cluster copper array connectors which where clean.
I am concluding a burnt ignition switch and possibly a burnt headlight switch. Any comments appreciated.
06-15-2012, 03:17 PM
I suggest contacting BB member Papajam. Send him a PM (Private Message) requesting copies of his color-coded wire diagrams for that model Alfa. Include your email address and he'll send some .pdf files that will make chasing Alfa electrons much easier.
06-15-2012, 04:02 PM
Trained Professional
It could as simple as the indicator bulb being burned out.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
06-15-2012, 05:51 PM
And, IIRC, that bulb has to be a specific wattage. (which does not mean I remember what wattage that is...)
06-15-2012, 08:49 PM
We thoroughly checked each bulb for continuity as we cleaned the etched circuit and will check again, thanks. We are intermittently working on this car at a remote location where it is stored.
With the instrument panel installed and harnesses connected we tried trouble shooting the circuit. Although there was a live battery voltage feed on the pink wire, when the ignition switch was switched to the "ON" position, the voltage did not appear at the connector for the green field wire. This is what makes me suspect the switch.
06-15-2012, 08:52 PM
thanks; I did so and appreciate the generosity of that offer by Papajam.
06-15-2012, 09:06 PM
I just opened my email and received the diagram from Papajam; much thanks indeed. Is it suggested that I donate to the forum or to him personally. I use PayPal. Thanks.
06-16-2012, 05:28 AM
Push hard and live
Moon,
Before spending too much brain time on this, run a completely separate, new wire from the alternator B+ (main power out) terminal to the stud on the left front wheel well where the original red main-power wire connects. It is a common problem that the original wire can appear OK, but refuse to carry current. After much head scratching and testing, I followed the experience of others on the BB who had this problem, and it cured my alternator output issues. You can leave the original wire in the bundle and just run a new one, or fiddle the old one out and run the new one as part of the old bundle. The main thing is to NOT believe your eyes, and try a replacement main-battery output wire.
Don P
Carson City, NV
Past Alfas...
Current Alfas
1971 Alfa Montreal (see above comment regarding rationality)
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
06-16-2012, 10:11 AM
Originally Posted by DPeterson3
Moon,
The "original wire" (green field wire) is in two pieces, one running up from the alternator with the B+ wire and connecting to a long blade and the other piece connecting to the other end of the long blade runs to the instrument panel. I am complaining about the piece running to the instrument panel not being energized on placing the key into the start position.
in which bundle? their is a small bundle coming up from the alternator and and the bundle running through the firewall. Are you suggesting that I power the field wire to the alternator from the stud on the firewall? When I had the alternator bench tested we had 60A and 14V coming out of that B+ wire, i.e., I tested it WITH the B+ wire attached so I know it is good.
What I also know is that the field wire voltage feed from the keyed circuit at the instrument panel is NOT live. How can I not believe my eyes?
I appreciate your comments and especially the note that others have had this problem or one similar to it. I will research further on the board.
06-16-2012, 11:49 AM
Push hard and live
I probably wasn't clear.
There is a reddish (I think) wire that goes from the largest terminal on your alternator up to an even larger stud that is mounted on the left wheel well. The large stud on the wheel well has several wires terminating there. Put a new wire between the largest stud on the alternator and the bigger stud on the left wheel well. Ignore all the voltage tests, labels, etc. Try this. It is super easy to do, as you just make up a fat piece of wire with two ring terminals and screw it in place. The original wire appears too small of a gauge to me, so I used something fatter. Don't recall the gauge, however. Use your eyeballs and pick something fatter than the original. It's easier to get to the alternator by removing the air filter tray, and probably quicker than trying to work around it.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
06-16-2012, 04:12 PM
Yes that was more clear to me; as I said I KNOW the alternator works and outputs through the wire to which you refer. I had the alternator----WITH the red wire output wire attached---tested on an Alternator/Starter business' shop bench tester. We energized the field wire and drove the alternator with the shop motor belt and out the other end of the wire to which you refer came 60 Amperes @ 14V on load and a steady14V when not loaded. The alternator is rated at 55 Amperes @ 14 V. Done.
However, it is my opinion from troubleshooting the green field wire blade at exactly the left wheel well relay post to which you refer that the field wire is NOT being energized with battery voltage. And this explains why the known working alternator is not outputting when attached to the vehicle.
As another person said here, that could be the result of burnt out bulb at the instrument panel even. We will look at that possibility again at our next engagement with this problem in a couple of weeks.
The way I understand the working of the alternator is that when the key is turned to the "RUN" position, the alternator field wire needs to be energized with battery voltage via the connection at the wheel well. It is NOT being energized and is in fact showing 10 ohms resistance to ground (with the key in the "OFF" position).
Hmmm?
06-16-2012, 05:15 PM
Push hard and live
I was not referring to the relay post, just to a gang-post on the wheel well. I was not referring to the field wire, but to the main bus feed wire from the alternator to the gang post.
The main bus wire from the alternator to the post is wrapped up in a bundle of wires, so it is interesting that you removed it to test it. The normal procedure would be to disconnect this wire at the alternator in order to remove the alternator. I didn't bother removing the original wire from the wrapped bundle, and just tie-wrapped the new wire along the bundle when I determined that it was the problem.
If it is not the main feed wire, that's OK with me, but all I can repeat is that I am NOT referring to the field control wire or the relay post. It is just a gang post on the wheel well.
Of course, you can chase the problem, and it could well be something in the excitation circuit. I was just trying to share that the main bus wire is a common failure point, and very easy to replace without a lot of bother to test.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
06-17-2012, 09:33 AM
OK; the gang-post on the wheel well. The bundle from the alternator comes up to it and meets a bundle which includes a straight feed from the battery. I thought then and think now that we are speaking of the same thing.
Yes we just brought the alternator along with the wire bundle up to the wheel well after removing the air intake box stuff feeling it was simpler than disconnecting the wire at the alternator while laying on one's back in an awkward position.
I understand and understood at the beginning of the last round of communication and tried to indicate that I did. "gang-post" it is. Where would the "relay post" be and what is that then?
I am going to HAVE to chase the problem in order to get a working alternator; they won't work if the field circuit isn't energized. AND I do sincerely appreciate your sharing the problem you experienced with me and the fact that there is some history about alternator funkiness that can be researched here. I am all in favor of quick and intelligent work arounds such as you suggested here. Thanks.
06-17-2012, 09:52 AM
I also changed the power wire from the alternator to junction box like Don. Also I added a ground wire from the alternator bracket to engine mount. This helped a low voltage problem for me. All the relays you see are for my headlights and fog lights. This does not address your question directly, but helped me and others.
Richard
76 Alfetta GTV gone to rust haven, 89 Spider the red graduate, 86 GTV6 on wish list
06-17-2012, 11:40 AM
The question is was the green wire hooked up all the way to the alternator? If it was hooked up, expect only about 1.5v. With the green wire disconnected, say at the junction block, with key on you should get about 11.5v (battery voltage minus the voltage drop across the bulbs filament resistance). If no voltage, suspect a burned out bulb, no switched voltage to the bulb (pink wire from fuse #6 to dash connector C10D pin 5), connections or wiring.
