11-08-2005, 11:57 AM
Help--I can't get into the trunk!
Hello,
I'm a new user and new Alfa owner--actually the car is an 86 Spider Veloce. Anyway, I pulled on the latch to open the trunk, and the cable snapped. I tried to repair it, but no dice. Is there any other way to get into the trunk than by pulling the damnned lever? Tell me the design is not so stupid, please!
11-08-2005, 12:03 PM
1990 Spider Veloce
1992 Toyota 4Runner SR5 3.slow
1993 Honda CBR600F2
11-08-2005, 12:20 PM
There is a hole directly under the trunk latch under the car. It is about 1/2 inch in diameter and you can stick a long screwdriver up to manipulate the latch to open the trunk.
Art Graham
'86 White Spider Graduate
'83 White (& Orange) Jeep CJ-7
'84 White Honda Spree (Summer Village Transport)
'99 Black BMW 323i--Kids can't touch it.
'03 Blue BMW 325XIT--Mine!
'03 Volvo X/C 70 (SWMBO)
Too Many Cars in the Driveway!!
11-08-2005, 01:16 PM
Thanks!
Thanks a lot for the advice--I'll go find a long screwdriver. I read on the thread you provided that this piece is fairly easy to fix, and that you can actually get away with using the exiting cable if you loosen it at the trunk latch and then pull the slack back through the sheath and attact it to the lever. I tried to do something like this, but I cannot cut the sheath? What sort of tool does one use? I tried a hacksaw blade but made little headway.
Thanks again!
11-08-2005, 01:25 PM
Just get a new cable. If it broke once, what makes you think it won't break again?
$11.50 @ IAP. Cheap Insurance.
Art Graham
11-08-2005, 01:58 PM
I'm with Topkick, replace the cable. While you are at it, I'd recommend adding a back-up cable for the hood. There is no emergency slot up front!
Btw, the design is not stupid, just different. Like brake pads, the cable is a wear item that needs replacement from time to time. The remote release makes it much more difficult for the bad guys to break into your trunk.
Mike Macaulay
Seattle
84 Spider Veloce 69 GTV 66 Giulia Super 64 Giulia GTC 57 750b
11-09-2005, 09:22 AM
Back Up hood release design
Is there a back up hood release design that seems to work well? If so is there a link to it.
11-09-2005, 09:39 AM
Replacing the Cable
What is IAP? Do they have a website? I tried IAP.com and I think it's the wrong site. Also, do you know whether or not the parts come with instructions?
Thanks!
11-09-2005, 09:54 AM
IAP is International Auto Parts. http://www.international-auto.com/
If you look in the Anything about Alfa Romeos and AlfaBB.com forum, you'll see a sticky thread near the top with a Suppliers list. Lots of good info to be had there.
Bob Farace
11-09-2005, 10:03 AM
Alfarich: You can make a simple safety release with some heavy gauge nylon line. Tie one end to the latch mechanism where the cable attaches. Follow the route of the hood release cable back to the interior. Loosely zip-tie the nylon line to the hood release cable to keep it in place. Tie something you can grip (old key ring?) to the end inside the interior. Make it short enough to not be noticeable under the dash. Also make sure it moves freely and rotates the hood latch fully. I think the Alfettas had them from the factory and they are a good idea on any Spider or GTV.
Mike Macaulay
Seattle
11-09-2005, 10:05 AM
Hmmmmm. What do you do if you lose your hood cable and don't have a backup? Are you totally screwed? Break out the saws all?
78 Alpha Romero Spyder
Motronic Pistons
HP Spica
Head goodies
Ugly, but big in fun.
11-09-2005, 11:55 AM
I have seen more than one hood with a hole cut through it!
Mike Macaulay
Seattle
12-11-2005, 02:43 PM
Did you ever get in?
Through the hole in the bottom? I am having a bear of a time trying to pop it. Any advice?
12-11-2005, 05:56 PM
I went out to measure the distance that you have to reach from the hole up to the lever. I measures 7.5 inches to the lever, so make sure you have at least 7.75 inches inside the car. I took a picture of the latch, but can't get my computer to recognize the camera at the moment. I'll post when it comes back up.
Art Graham
12-13-2005, 05:44 AM
Toptick - that would be greatly appreciated. The wife's Spider had the cable pop the other day on her. I tried pulling back the cable sheathing, hoping I could find the cable to pull with some vice grips but had no luck. I looked in the back up under the trunk but didn't see any hole, but that was before I saw this thread (it's a 1990 BTW). If you happen to have a photo of where to find the hole (no W-A comments please), that would be great. I've got a cable on order from IAP but I'd like to get into the trunk ASAP... My wife left her "lunch box" in there. I know that in most of the country this doesn't pose too much of a problem as right about now the trunk is somewhat of a refridgerator, but here it S. Florida it's still fairly warm and I'm afraid if I don't get to it soon..., well I think you get the picture!
1990 Alfa Romeo Spider Graduate - "Marcello"
1991 Mazda Miata - "Suki"
1973 Datsun 240Z - Yet to be named
2000 Ford Explorer Sport Trac - Yet to be named
