Thumping upon acceleration - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 12-29-2010, 05:49 PM Thread Starter
mr.epi's Avatar
In my '91 Spider Veloce I am getting a thumping sound from what sounds like the rear. The sound happens only on starting off from a standstill in first gear. It seems more pronounced on making a turn from a standstill, either right or left, and is only in first gear. The thumping sound is a fairly rapid "pum, pum, pum , pum, pum," and ends quickly.
I just finished installing new rear shocks and springs. Any ideas? Thanks.
mr epi
mr.epi is offline
post #2 of 10 (permalink) Old 12-29-2010, 06:54 PM
cabikefreak's Avatar
I'm probably not the guy to help you with this but did it make this sound before you did the shocks and springs?
Gene
'71 GTV 1750 USA SPICA
cabikefreak is offline
post #3 of 10 (permalink) Old 12-29-2010, 06:56 PM Thread Starter
mr.epi's Avatar
Hi Gene. No, it did not make the noise before the new shocks and springs. I figure it must be related but I do not know how.
mr.epi is offline
post #4 of 10 (permalink) Old 12-30-2010, 01:36 AM
garwood1's Avatar
Send a message via Skype™ to garwood1
It's bound to be one of the following:
U-joint siezed (the eventual cause of my thumping on acceleration)
Center propshaft bearing support with perished rubber
Transmission mount with perished rubber
I'd check these, before moving on to the more difficult to diagnose (and more costly to put right) worn-out trailing arm bushings or other rear axle bushings.
Good news is that none of the first list are crippling in terms of cost to repair.
Lots of threads within this forum on each of the above topics...have a meander through those to get a better idea of symtpoms that match yours, and the probably causes.
Chris
1977 Spider 2000
garwood1 is offline
post #5 of 10 (permalink) Old 12-30-2010, 08:23 PM
Member
My 2 cents worth is it's the flexible joint disk (the rubber donut) on the drive shaft. I had a simular experience.
Jim P
87 Spider Veloce
spiderjimp2 is offline
post #6 of 10 (permalink) Old 12-30-2010, 08:32 PM
Vintre's Avatar
Hmmmmm.......sounds familiar
First Gear Shudder
Transmission mount is my guess.
Good luck.
Vin
Vintre is offline
post #7 of 10 (permalink) Old 12-31-2010, 11:41 AM
Dickson's Avatar
My bet is that it's the flex donut / guibo, but it would be a good idea to check the driveline center bearing & tranny mounts too.
A.L.F.A
Dickson is offline
post #8 of 10 (permalink) Old 01-10-2011, 05:41 AM
Alan Brink's Avatar
I recently had exactly the same problem with my 1980 ex American Spider. It was the rear universal joint on the tail shaft / drive train or whatever you call it over there. I am in Australia. So I replaced the two uni joints just incase the other was also wearing. Problem solved - QED.
Cheers.
Alan Brink is offline
post #9 of 10 (permalink) Old 01-10-2011, 06:40 PM
msiert's Avatar
I agree................flex donut
Murray Darkside Member
msiert is offline
post #10 of 10 (permalink) Old 01-10-2011, 08:22 PM
Hey guys - I had similar donuts on a Lotus Elan (on the halfshafts). Sitting on the ground you couldn't tell if they were torn up. I don't have any symptoms on my GTV but with it in place it would be hard to see a tear, correct? So do you just replace them after a certain time period, whenever you are in there anyway or when you hear the symptoms as described here?
Gene
