1967 Dunlop brakes - Alfa Romeo Bulletin Board & Forums
Old 01-24-2010, 07:31 AM
1967 Dunlop brakes
My Duetto is soon to leave the body shop and come home for completion. Out of service for 21 years, but used as garage ornament.
I have been unable to locate a rebuild kit for 3/4 inch Dunlop master cylinder from the normal suppliers. Can an ATE (or any other) mc be fitted, with a reasonable amount of modification, and hooked up to my pedal?
Old 01-24-2010, 08:32 AM
papajam's Avatar
Trained Professional
The Dunlop kit is listed on Alfa Stop's website.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
Old 01-24-2010, 10:33 AM
You can use a later MC, but the pipe connections are different. But with changing them you can use an ATE, Bonaldi, Benditalia, whatever MC as long as it's physically the same.
I bought full MC, front, and rear kits from AlfaStop to rebuild the Dunlops on my 65 TI and so far so good. I had to buy new front pistons as mine were rusted beyond use.
The whole system can be swapped for a later ATE if you want, but in front you have to change spindle, disk, caliper, and in rear you swap the axle.
Andrew
Old 01-29-2010, 04:50 PM
I don't want to jinx it, but I haven't gotten a quote back from Alfastop, this time or the last time. The parts I need do indeed appear in the online catalog, but it's a long way from Chambersburg to Tony's shop in UK.
Old 01-30-2010, 01:48 AM
Alex's Avatar
Bruce,
If Tony Stevens is proving a little too slow, I would try contacting Past Parts (also in the UK). Although they do not have a specific online catalogue, they are likely to stock this kit. I've used their services in the past and they come recommended.
Good luck
Alex.
Old 01-30-2010, 08:09 AM
Folks in the UK tell me phoning Tony is best.
Andrew
Old 01-30-2010, 09:15 AM
Wille R.'s Avatar
Duetto, just Duetto
Tony Stevens at Alfa-stop is there, but he has some e-mail problems, but he will respond. I am sure.
1967 Roundtail Spider, "Duetto" Mine since 1970, more than 40 years.
My Duetto sites www.veloce.se and the www.duettoregister.com The Mille Miglia www.orsoveloce.com
Old 01-31-2010, 10:57 AM
Mound Dawg's Avatar
Fedex?
Jim.Spackman@alfaholics.com
Not fast, just furious.
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
