#16 (permalink)
Old 11-03-2009, 09:48 PM
jarrington's Avatar
Originally Posted by SpiderWebb View Post
There are special tools to stop the flywheel from spinning while loosening and tightening the flywheel and pressure plate. I was in a hurry and improvised. It worked for me. But your mileage may vary. I could see if you bent one of the engine block studs it would be a real pain to repair. The problem is, those special tools also use the studs or a bolt in the block. Spread the torque around as evenly as possible and use liquid wrench to help things along.
If'n you don't have the factory tool there are a couple of tricks you can try; I've read that there's a VW tool that can be made to do the job, or if you're lazy/ cheap you can stick a screwdriver or similar tool through a hole in the flywheel and rotate the engine until the tool wedges against part of the engine block. Or so I've heard.
-Jason
Jason Arrington
'60 Giulietta Spider
'67 Super - Project no more!
  #17 (permalink)
Old 11-04-2009, 01:21 AM
Mound Dawg's Avatar
I use a 6mm allen key through one of the top transmission mount holes on the engine. Let the tail drop onto the teeth of the flywheel and it'll lock it solid. No special tools required!
I can't see how bending the gearbox mounting studs would be difficult to repair either,
1. You can buy them new
2. They come out really easily. I take them out and put them back in all the time!
Jim Spackman
www.alfaholics.com
  #18 (permalink)
Old 11-04-2009, 05:33 AM
Tifosi's Avatar
Darth Slacker
If you really, really had to for lack of any other means, you could remove #4 spark plug, and with the engine on the compression stroke for that cylinder, (you know, so both valves are fully closed), run a length of cloth clothesline down into the cylinder then roll the engine til the clothesline wadded up between the combustion chamber and piston crown.
Darren
as hosted by
Greg Gordon's HI Performance Store
  #19 (permalink)
Old 11-04-2009, 05:38 AM
Flywheel lock
Here is the VW tool that works. It costs $8.95.
Universal Flywheel Lock Chirco Performance & Restoration
79 Spider Veloce
85 GTV6
88 Milano Verde
88 Milano Verde
  #20 (permalink)
Old 11-04-2009, 09:52 AM
Gordon Raymond's Avatar
Contact Don Brubaker, Illinois local chapter AROC past president for an original Alfa tool. 847-550-8915.
Gordon Raymond
  #21 (permalink)
Old 11-04-2009, 02:37 PM
SpiderWebb's Avatar
Wow! Save this thread, if only for the flywheel hold data. alfabb.com is great.
1981 Spider 2000 USA - It's SpiderWebb cuz' Webb's my last name.
  #22 (permalink)
Old 11-04-2009, 05:08 PM
the starter you need is the smaller one for 1972-1974 and the 90-on (motronic)
the best one is the new type use on the 90-on motronic 0 001 108 0011 but almost imposable to find.
the 0 001 108 024 is for 1975-1989
I got this one and had a custom 10 tooth bendex put on and it works great.
the old type starter for 72-74 is .7Kw starter 000 121 1987
The ring gear on the flywheel had 130 teeth
the 75-89 use 131 teeth as well as a slightly larger (+1 cm) diameter
1987 black Milano Verde
1972 White spider 2000 Veloce
  #23 (permalink)
Old 11-04-2009, 08:14 PM
tom shewchuk's Avatar
I got a tip from a friend of who I should have called before I pulled my trans to replace the throw out bearing. Unbolt the exhaust at the back of the car so it rests on the rear axle. It's enough weight to lift the front of the motor so you can clear the lip on the firewall with the bellhousing. Check your front,and rear transmission seals. You've got it out. You don't want to have to do it again to replace a $6 part.
  #24 (permalink)
Old 11-05-2009, 01:34 AM
Mound Dawg's Avatar
Maybe over there but I've got a big pile of them on the shelf here! The starter is the same as the one in the 75 Twinspark. We use them because they have a gear reduction mechanism and a big chesty motor in them so they'll swing a high compression engine over nicely. Paradoxically they're actually lighter than the old style Bosch starter fitted to the Spider/GTV so it's "Win" in every direction.
We've also got them in 8 tooth for smaller engines.
Jim Spackman
www.alfaholics.com
  #25 (permalink)
Old 11-05-2009, 11:01 PM
Once again, thanks to all for all the great information. I bought the transmission lift at Harbor (I've never been in a Harbor store...this discovery is going to cost me big time; what a great man tool store!). Parts are in the UPS delivery system, and should arrive in time for the weekend. Sadly, my bride will be out of town...it will just be me, my tools and my spider; does it get any better than that? (Probably not for me!!!). I have to admit, I feel a bit like a nervous groom, not totally sure what to expect when I remove the tranny from that curvaceous bell housing...man, should I film the operation for youporn?
(yeah, guys, pretend you don't know!)
  #26 (permalink)
Old 11-06-2009, 03:21 AM
Tifosi's Avatar
Darth Slacker
You'll think it's sexy like that, right up until you discover what a fat heavy pig she can be while humping her out the side or toting her to the bench for cleanup while she's out. (being the dirty girl that she most likely is)
At least you got a jack and likely won't know just how heavy she can get while trying to press her off your chest.
Still, you will sweat.
Darren
as hosted by
  #27 (permalink)
Old 11-06-2009, 07:06 AM
ghnl's Avatar
Originally Posted by farklevill View Post
it will just be me, my tools and my spider...
Work safely. Make sure the care is safely supported on jack stands.
And don't forget what Frank told you in reply #10 - you must use the proper shouldered bolt when installing the starter motor. That bolt positions the starter motor in the correct position relative to the flywheel.
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
  #28 (permalink)
Old 11-06-2009, 07:24 AM
Graham D's Avatar
...does it get any better than that?...
No, it doesn't. Do take extra care undoing the drive shaft coupling nuts and bolts as they, like the starter shoulder bolt are not hardware store items though replacements can be sourced from BB members and aftermarket suppliers such as IAP, etc.
Guys with tools working on cars; male bonding. Have a good time!
  #29 (permalink)
Old 11-06-2009, 12:39 PM
Thanks for the reminder about the shoulder bolt...that's the first order of business, to make sure I installed it in the correct place last time! That would make for so much simpler a repair, to forget all this flywheel/clutch/etc., etc., and to simply place the shoulder bolt in the correct spot. Much humiliation, but a lot less work. I'm curious, though...how does that shoulder bolt make a difference (as I know it does!)?
  #30 (permalink)
Old 11-06-2009, 12:55 PM
It actually locates the starter correctly. I guess that Alfa figured it would be easier to install the starter if the hole was oversize, and then locate it accurately by a shouldered bolt. If the bolt holes were exactly right for threaded bolts, you'd have a tough time getting the bolts in without buggering the threads.
Ian Cameron, 1980 Spider
