#16 (permalink)
Old 11-02-2009, 07:57 PM
Gubi's Avatar
Damn, that's weird. That's got to be a typo or something. If that's correct they'd run crazy hot in a car.
Check the black printing on the glass - what does it say?
1991 Spider
1987 Milano Gold
  #17 (permalink)
Old 11-02-2009, 08:08 PM
DavidH's Avatar
Black print on the bulbs: "12/1.2"
Hmmm again.
David
'91 Red Spider
  #18 (permalink)
Old 11-02-2009, 08:09 PM
Gubi's Avatar
Well, that's correct then: 12V/1.2W. So the bulbs are fine, but it appears the labeling on the package is fubared.
1991 Spider
1987 Milano Gold
  #19 (permalink)
Old 11-02-2009, 08:16 PM
DavidH's Avatar
Now, anybody know a reputable source for them at less than Autozone's price of $2.50/bulb. At that rate, it would run more than fifty bucks to replace all 22 bulbs in the instrument cluster. Ouch.
David
'91 Red Spider
  #20 (permalink)
Old 11-02-2009, 08:19 PM
radamm's Avatar
Fast in Black!
Think ebay.
__________
Rick
69 850 Spider
81 Spider Veloce
  #21 (permalink)
Old 11-03-2009, 04:25 AM
Tifosi's Avatar
Darth Slacker
Did I mention a junkyard?
'Course if you were truly evil, you could scan the used car ads for private sale vehicles in your area, take one out for a test drive, and pull all the dash bulbs while out there by yourself.....
Darren
as hosted by
Greg Gordon's HI Performance Store
  #22 (permalink)
Old 11-03-2009, 05:21 AM
Ok watched you guys ping-pong on the bulbs, but I have a more essential question, how do I get into the back to change the bulbs? Is there an easy way? I have one bulb that is out, but there's enough ambiant light from the others that I haven't attempted the change.
KKKKFL
  #23 (permalink)
Old 11-03-2009, 06:28 AM
Tifosi's Avatar
Darth Slacker
On dual pods you take the speedo and tach out of thier pods and reach behind the dash from the passenger side for the triple gauges in the console.
On mono pods, you remove the cluster as a whole from the front after taking off the trim/retaining rim.
Darren
as hosted by
  #24 (permalink)
Old 11-03-2009, 07:05 AM
DavidH's Avatar
I see on ebay some pretty inexpensive LEDs that appear to pop right into the place the 2721 incandescent bulbs go. Has anyone used them in this application? Is there any downside to replacing the incandescent bulbs with these LEDs? Are they so bright such that they'd mess up your night vision? Are they controllable -- or even compatible -- with the rheostat (the dimmer)?
David
'91 Red Spider
  #25 (permalink)
Old 11-03-2009, 07:14 AM
Tifosi's Avatar
Darth Slacker
A reostat can control LED's quite well. (I've got one in my shift knob and a couple others here and there that operate on that circut)
The lifespan of the things is practically eternity compared to an incandecent bulb, but they're not all that cost effective IMO (unless you pull them all out to use in another car once you're done with the one they're in)
I priced out such things for mine via Autometer's offerings a bit ago, and it came to something just over $120 to do almost all of the gauge and console bulbs. (some they just didn't have replacements for, so conventional bulbs would have to remain)
'Course they draw less juice, so if your ultimate goal is to save a volt or so, they would indeed be of use toward that end.
Darren
as hosted by
  #26 (permalink)
Old 11-03-2009, 07:16 AM
As I already mentioned, I bought a box of 20 (or about 20, maybe it was 18 or 24), at NAPA for ~$10 a few years ago.
  #27 (permalink)
Old 11-03-2009, 07:17 AM
Tifosi's Avatar
Darth Slacker
Oh, and if you do get some LED's, and your backlights are normally colored/tinted when on, buy them in that color shade, not white in the hopes that the filters in the instruments will correct for it.
'Cause they won't.
Darren
as hosted by
  #28 (permalink)
Old 11-03-2009, 07:23 AM
Anybody have a picture of the trim ring off and the instrument panel pulled forward?
KKKKFL
  #29 (permalink)
Old 11-03-2009, 07:24 AM
Tifosi's Avatar
Darth Slacker
There might be one in JohnM's 'how to fix your slow reading speedometer' thread.
Darren
as hosted by
  #30 (permalink)
Old 11-04-2009, 03:15 PM
KKKKFL
The trim ring comes off by squeezing in the edges, and then wiggling it out from behind the steering wheel. Sounds worse than it is, but you'll feel/see what I mean. The gauge pod comes out after removing several Philips screws, but merely pulling it forward will not offer you access to the bulbs. There are three harnesses/plugs at the top/rear of the pod, and all three need to be released and the pod removed from the car. Each harness has a different-shaped plug, so you can't screw up the re-installation. Each bulb has its own holder, which is removed from the circuit board with about a half-turn CCW.
