09-05-2005, 11:05 AM
Upper arm bush going bad after 2000 miles?
Hello all,
I purchased a pair of adjustable upper arm back in July this year and installed them on my 91 spider. It's only been a couple of months & less than 2000 miles, but the rubber part of the upper arm bushing at the body (right by the tpo shock absorber mount) came out of the metal sleeve of the bushing... When I checked with the vendor, I was told that I shouldn't have assemble the arms with the tires in the air. That is, once I loosely assemble the parts, I should lower the car to the ground and get any slack off before I tighten all the nuts & bolts. If this is true, would someody please tell me how I can accomplish this (I think there is not enough space to use wrenches or ratchet on suspension when the car is on the ground)??
Thank you always,
tiger0529
[SIZE="3"][B][FONT="Arial"]Taiga [I]"Tiger"[/I] Inoue[/FONT][/B][/SIZE]
1991 Spider Veloce/1967 Sprint GTV (in Japan  )/1970 300SEL 6.3 (in Japan too  )
My mother owns 25 alfas
09-05-2005, 11:26 AM
I've done such repairs by lowering the car while jackstands are under the lower balljoints (or rear axle), which will fully load the suspension and allow room to work. Nonetheless, it seems that the quality of many aftermarket parts we all buy has really gone into the toilet. Why do bushings that I replaced 20 years ago on one Spider still look better than those same bushings replaced on another Spider just a few years ago? Same seems to be true for motor mounts.
Regards,
Dean
Lutz, FL
'74 & '87 Spider Veloce's
09-05-2005, 12:57 PM
I can't answer your question but I'm curious as to where you purchased the arms and what brand they are. Were there any instructions telling you to preload the suspension before tightening them? Just curious and would like to know how they are supposed to be mounted before I do something like you did. Thanks!
La vita e troppo corta per non guidare Italiano! (Life's too short not to drive Italian!)
You're traveling through another dimension, a dimension not only of sight and sound but of mind. A journey into a wondrous land whose boundries are those of imagination. That's the sign post up ahead. Your next stop: [COLOR=Red]The ALFA Zone[/COLOR].
Ron Linhart
'76 Spider Veloce(tucked away in my garage)
'76 Spider Veloce(a roller)
'79 Spider Veloce(parts-donor lawn ornament)
09-05-2005, 03:40 PM
with the Librarian
Pivoting rubber bushings with bonded inserts (or sleeves), on any vehicle, and unless specifically stated to the contrary, should be tightened only when the bushing is in the neutral position. For suspension bushings, this means that the vehicle should be at rest on the ground and normally loaded. If the bushing is tightened with the bushing in rebound (unloaded), not only is the sleeve to rubber bond stressed, but the bushing will add to the spring rate effectively raising the vehicle a little.
From Alfa info sheet 21.69.4.2.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
09-05-2005, 04:43 PM
First of all, thanks to all those who wrote me a reply so far.
I guess it was my mistake that I tightened the bolts/nuts when the tires were in the air... I learned another lesson, thanks to all of you here at alfabb.
As to the identity of the vendor, I am not going to disclose it here since they have been terrific and extremely helpful to both my mom (owns alfa repair shop in Japan) and me for years. The brand of the arms is... well, it is FLAP, which some people absolutely hate, but it seems that it was simply my mistake that caused the bushing to wear out prematurely so I am not going to attribute this occurrence to the company who makes them.
Thanks to you all again,
tiger0529
09-05-2005, 05:51 PM
Glad to hear that the vendor was so helpful. I wasn't asking to throw any flames their way but just out of curiosity. Since they did work things out, naming them would let others know that they are good to deal with. Do parts like the adjustable arms come without any instructions?
Jim, as usual, you are the man!
Ron Linhart
09-05-2005, 06:47 PM
with the Librarian
Sure. Many parts like ball joints, starters, crankshaft seals, clutches, headlights and countless other parts may or may not come with instructions. Can't recall ever seeing a box of fuses come with instructions nor a set shocks with bleeding instructions. When was last time anyone saw instructions in a box brake pads for a 105/115 to check the alignment of the caliper pistons? It is assumed in many cases by the parts manufacturer (not the vendor) that the installer has previous training, experience or knowledge in the proper replacement procedure. Fortunately, most of the time many parts are fairly straight forward to change and require no special instruction. It is those 'special cases', like suspension bushings, shock bleeding and piston alignment that without proper instruction, can ruin someone's day.
09-05-2005, 09:23 PM
Originally Posted by papajam
Can't recall ever seeing a set of shocks with bleeding instructions.
Please explain ... new one to me.
09-06-2005, 04:32 PM
with the Librarian
