Removing Centrifugal Mechanism - Alfa Romeo Bulletin Board & Forums
Old 08-01-2009, 12:57 PM
I have on my '81 Spider what I believe is a Marelli distributer with the centrifugal mechanism above the contact breaker. I can't figure out how to remove the centrifugal mechanism to get to the points. I removed the one phillips head screw, but that wasn't it. Here's an image:
Thanks.
Jay
Old 08-01-2009, 01:52 PM
radamm's Avatar
The 81 came with electronic ignition. It has a pickup, not points. The two wires on the right are to one of the pickups.
__________
Rick
MEMBRO LATO OSCURO
69 850 Spider (A fond college days' memory)
81 Spider Veloce
Downstate Illinois SNO Director
Old 08-01-2009, 02:33 PM
Alfajay's Avatar
radamm offers you good advice. Looking at that single, heavy white cable coming out of your distributor, yea, it does look electronic.
However, to answer your question: you can't remove the advance mechanism without disassembling the distributor. And, you need to remove the distributor from the front cover to do that.
Yea, this is a hokey design - why Marelli put the advance weights to the top, instead of copying the configuration of the earlier Bosch distributors, is beyond me.
'63 Guilia spider
Old 08-01-2009, 06:25 PM
Thanks for the replies. I've never worked on an engine with electronic ignition. Can anything go out of adjustment in the distributor that would make the engine run poorly and that I can adjust myself?
Thanks.
Old 08-01-2009, 08:13 PM
radamm's Avatar
There is an air gap to be concerned with, between the pickups and the reluctor. This is something that once set is usually good for life. If the distributor bushings became worn and allowed excessive lateral play it would affect the gap. This gap can vary quite a bit and not affect how the engine runs.
__________
Rick
MEMBRO LATO OSCURO
81 Spider Veloce
