Old 07-28-2009, 07:13 AM
Send a message via Yahoo to iracema1
88 Spider Veloce starting anomalies!
Hi Everyone:
My 1988 has had an intermittent starting problem that has suddenly become constant! After sitting a few days, the car would crank and crank (just fine, both battery and starter are relatively new), but wouldn't start. Then (if I am at home), I put it on a battery charger, and after 45 minutes or so, it starts up right on the first crank! Recently the problem is such that even if the car just sits overnight I have this issue (and not always a convenient slow charger for the battery).
Is this an ECU issue that is requiring an optimal charge in order to send the right messages for fuel and spark? Otherwise I cannot understand why putting the car on a charger "cures" the issue so effectively. Any similar experiences out there?
Best
Andy
Old 07-28-2009, 08:31 AM
ghnl's Avatar
I'd look for a small electrical drain somewhere that draws the battery down. The computers must see >10.3V to wake up and send the spark/fuel signals. The engine may crank over with seemingly good effort but if the available voltage drops during cranking, no start.
A common source for such a drain is one of the footwell lights. The cover acts as its switch - one way is automatic (with door open/close) moved the other way is always on.
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 07-28-2009, 05:24 PM
Maybe that's why my footwell lamps are never on....Not a big issue, but I like to have everything working. It took me a year and this forum to realize that the trunk lights don't work unless the parking lamps are on. DOH!
'86 Spider Quadrifoglio, '01 Audi S8, '01 and '89 Range Rovers, '65 Chevy pick-up, 2 Volvo 940's
Old 07-30-2009, 08:38 PM
No spark!
Updates: pulled plug wire and attached extra plug, had friend crank car and no spark on plug. Seems pretty definitively a sparking issue. Going to chase down bad connections and ECU unit and report back later
Andy
Old 07-30-2009, 09:15 PM
No voltage at coil positive terminal
turned car to "on" position and checked for voltage at coil positive terminal and none! Where would you look next?
Old 07-31-2009, 04:26 AM
SamW's Avatar
The number 7 fuse, check there first.
'86 GTV6 - No Name
'89 Spider Quad
'89 RC30
Old 07-31-2009, 01:51 PM
No. 7 fuse?
In the regular fusebox? That sounds too easy but crossing fingers it is. Are there other inline fuses or resisitors in front of the coil?
Old 07-31-2009, 04:37 PM
papajam's Avatar
Trained Professional
No.
Unfused power to the coil comes from the ignition switch, goes to the fusebox (without going through any fuses) and then on to the coil (green/black wire). If the connections at the ignition switch 3-wire connector and on the back of the fusebox are okay, suspect a bad ignition switch.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
Old 08-04-2009, 06:51 PM
Cannot find my CD Rom guide!
Could I ask some kind lister to provide me pages showing the ignition ECU, ignition switch and few of the other parts in question? I have been searching the house for a couple of days but cannot find my CD ROM. Thanks in advance
Best
Andy
Old 08-04-2009, 07:29 PM
ghnl's Avatar
What exactly are you looking for?
- - Eric
don't read this
Old 08-04-2009, 09:25 PM
Thanks for that! But, is there a picture of the ECU itself?
Old 08-04-2009, 11:28 PM
Tifosi's Avatar
Darth Slacker
ECU (injection): silver box, dark colored multiconnector, right side, under the cargo panel behind the seats. Can't miss it.
ICU (ignition): silver box, light colored multiconnector, right side, behind vertical carpet 'side lining' below the tops hinge point. Will likely have a sticker on it that says 'Motronic'
Clicking the link in ghnl's or my sig line for the spider diagnostics page will take you to a place where there's a photo of an ECU in location along with a schematic of the location for the ICU.
Darren
as hosted by
Greg Gordon's HI Performance Store
& OK Injectors
Old 08-05-2009, 04:07 PM
you guys are the best!
Andy
  #14 (permalink)
Old 08-05-2009, 08:51 PM
Updates: Battery checks at 12v. Opened ignition ICU and voltage supply test: 12v. Primary circuit check: 12v. Then starting signal, (test to be done while cranking), barely 5-6v where guide says should be between 6-10.5. Perhaps an "Aha" moment, as this indicates something faulty between the ECU and contact 50 in the IGNITION SWITCH. So, will do some checks there and report back. Couldn't have got this far without the kinda assistance of the folks on the list!
Best
Andy
  #15 (permalink)
Old 08-06-2009, 07:18 AM
ghnl's Avatar
Connect your voltmeter to the battery. Tell us what it measures during cranking. A marginal battery can make it sound like the engine is cranking over OK but if the available voltage drops below ~ 10.3V the computers will not wake up and go to work.
- - Eric
don't read this
