Old 08-10-2005, 08:48 PM
cbtbbb cbtbbb is offline
What fluid goes in steering box for 79 Spider?
Curious what fluid goes in a steering box....it is a 1979 ZF brand box.
Craig
Old 08-11-2005, 05:34 AM
papajam's Avatar
papajam papajam is offline
90W gear oil. Don't recall the quantity though.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 08-11-2005, 05:36 AM
alfaparticle alfaparticle is offline
If it doesn't leak - gear oil. 75W90 or similar.
If it leaks - grease, until you have time to replace the seal. AAA semi-liquid grease is easy to pour into the filler hole.
Ed Prytherch, Columbia SC
Old 08-11-2005, 09:40 AM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
If it leaks, change the lower seal.
John Stewart
74 Spider
Old 08-11-2005, 09:57 AM
Semi liquid grease is intended for use in leaking gear cases. It is widely used in underground equipment. It will not hurt your steering box.
Of course, it is best to replace the seal, but in the meantime grease will keep everything lubricated and prevent excessive wear.
Ed Prytherch, Columbia SC - Who has replaced seals but has also driven for several years with a grease filled steering box.
74 GTV
88 Verde
