12-13-2008, 02:23 PM
Starts and Dies 88 spider
I have an 88 spider that starts healthy and will run for approx 3 seconds and then dies. Once the car starts up you can rev the engine up but once it desides to stop it just putters out. Please any ideas.
12-13-2008, 03:05 PM
From what you describe, it sounds like the engine runs only on the CSI (cold start injector) which stops injecting once the Thermo/Time switch shuts it down.
Check that the fuel filter is nor restricting flow.
Other checks: fuel pumps, fuel pressure regulator (at end of the fuel rail).
The Fuel Injector ECU, not operating, because of bad ground(s) or blown fuse. Also check the Drive (tachymetric) relay under the rear shelf next to the FI ECU, that is the one that senses the coil operation and tells the FI ECU to inject.
If the ECU can't supply a ground, the injectors will not be able to inject.
Also see GHNL's signature page and link to his excellent Bosch L Jet diagnostics page.
TTFN Elio
[B][I][COLOR="Silver"]Quadrifiglio[/COLOR][/I][/B]
12-13-2008, 03:16 PM
i have a noid test kit and am going to see if the injectors are firing. sounds like they should not fire if there is any electrical issue. is that correct?
12-13-2008, 04:23 PM
Well the injectors are getting voltage, the noid light flashed rapidly untill the car cut out. thinking it might be the fuel pump. any other ideas
12-14-2008, 11:46 AM
This confuses me:
you can rev the engine up but once it desides to stop it just putters out...
So, does it only ever run for those 3 seconds or are you saying that if it starts you can rev it up but then it won't idle or it just dies?
Common things happen commonly so check the usual supects: intake air leaks & iffy grounds. The L-jet system is very sensitive to 'false air' - air that bypasses the AFM (Air Fuel Meter) will mess up the proper signals for fuel injection. So check carefully for loose, cracked or missing air & vacuum hoses. And the computer switches the injectors by controlling their ground connection so any iffy grounds will adversely affect proper operation. Don't trust that the connections look or feel OK, remove them, clean them and re-secure them. The main computer grounds are on the intake & the cam cover.
The drive relay is the other vital component. It must 'see' a tachymetric signal via the coil to then switch on and supply power to the fuel pumps. The drive relay will briefly power on the fuel pumps when you switch the ignition on but then it stops supplying power until the engine starts and the coil's field rises & falls signalling to the drive relay that the engine is running.
The CSI (Cold Start Injector) is not under control of the drive relay or the computer. It will squirt fuel for a few seconds based on the temp of the coolant.
Make sure the harness plug for the AFM is connected securely. And that the flap inside the AFM moves smoothly through its range of motion.
Peruse the Spider L-jet diagnosis page - a link is in my signature. I suggest you go through everything outlined there. The L-jet is a system - all components must be 100% for it to work properly & reliably.
12-14-2008, 01:15 PM
My bet is ,(as Eric suggested)... The Drive relay. I bet.... $1 trillion dollars, or GM, and Ford.... Whichever suits your fancy!
Peter L. Carver, MA
Spiders, spiders everywhere...
12-14-2008, 03:55 PM
Well i have been working on the car most of the day.
If you start the car it runs good for about 3 seconds.
If you rev it up and pat the gas it will run a bit longer but no amount of patting the gas will keep it runing and it seems to starve out of fuel.
here is a list of what we have tried.
1) looked for air leeks in the intake and found non (when running you can see the air intake hose compress a small about due to the vacume in the line)
2) used a noid to verify that the injectors are getting electrical signal
3) directly tied the inline external fuel pump to the battery and tried to start the car ( when doing this you could hear the pump and the regulator bypassing the extra fuel pressure when not trying to start the car)
4) disconnected the by pass side of the pressure regulator on the fuel rail and about 2oz of fluid comes out when the key is ingaged to the run position
5) hooked up to the feed line on the fuel rail and pressure goes to 55psi when the key is ingaged then if ingaged again to about 85psi
6) examined the air flow meter and it functions open and closed smoothly.
All of the above resulted in the same results with the car running for seconds and cutting out.
12-14-2008, 04:22 PM
Ok. I assume you have plenty of gas,(past 1/2 full to rule out the in tank pump and it's fickle often failed connection) and that your battery is FULLY charged. The vacuum leaks you assure us are not present, but there are many places they can be, so I will leave them up for further discussion.... The thread http://www.alfabb.com/bb/forums/spid...6-project.html will give you an insight on my recent finds on an 86 car, but I still suspect a relay issue, or at the worst, a major vacuum leak. good luck, and post your progression/regression. The drive relay is behind the passenger seat under the horizontal "back seat" area. It is prone to failure. It seems to be a logical or probable source of your specific issue. Good luck. Hope it is a simple cure!
Peter L. Carver, MA
12-14-2008, 05:39 PM
Can you hook up the fuel pressure gauge so it is "tee'd" into the supply line? That way you can observe if the fuel pressure remains adequate. I suspect the fuel rail is getting initial pressurization when you turn the key to 'start' but it is not remaining pressurized after the engine starts (and the key is not in the 'start' position). This would point to the drive relay not supplying power to the pumps.
Have you tested the two flywheel sensors?
12-14-2008, 06:07 PM
Trained Professional
Does the noid light continue to flash as the engine is dying (mixture problem) or stop flashing first and then the engine dies (ignition)?
As Eric said, the fuel pressure needs to get checked with a tee in the feed line prior to the pressure regulator. Spec is 32-36psi.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
12-14-2008, 08:47 PM
Here's the procedure from the Alfa Shop Manual:
02-08-2009, 07:56 PM
Well i finally got a chance to work on the alfa this weekend and the fuel system appears to be just fine. with a "T" in line with a pressure gauge as the car starts the pressure remains between 30 and 38 psi. One note as the car died the fuel pressure rose back to the initial pressure before turning the car over to start(38-psi). So my guess would be not anything to do with the fuel system from at least the injectors back. Does this help come up with any other ideas. My next coarse of action will be to pull a plug wire put an old plug in ground it out and check for spark.
03-06-2009, 08:04 AM
The fuel injectors may be clogged. I have been having similar problems with my spider so I replaced the battery with an optima deep cycle marine battery, removed and cleaned out fuel tank, installed new in tank fuel pump, checked primary pump pressure, installed a new regulator, installed an new coil, installed new wires, new plugs, new filter, new temperature sensor and checked vacuum connections. Finally unhooked fuel injector from block and tried to turn the car over. #1 injector sputtered a little and the other 3 just dripped.
03-06-2009, 09:36 AM
How was the fuel injector removal process, fairly straight forward?
03-06-2009, 09:52 AM
It is relatively easy. There are 2 hex head bolts holding the injectors in place. I unhooked the #4 first because it was easy to access. Once you remove the screws pull back on the injector until it clears the block. I leaned it against the cam cover to do the initial test to avoid kinking the injection hose.
